RADIATOR HOSE ISSUE
RADIATOR HOSE ISSUE
1992 3.0L V-6 RANGER
New thermostat
New Water Pump
Done By Others^^FWIW
Guys I noticed the other day that the Upper radiator hose gets Sucked Flat when RPM is higher than Idel BAD it compleatly collapses IDK how it can circulate the coolant very well in this Condition
IDK if the hoses have ever been changed But the Upper hose Really gets sucked flat.
Iv seen this a few times on vehicles that have been shutdown But they have always expanded upon startup and are fine
the Lower Looks Fairly Old and only partly collapses under higher RPM
I am going to change the Upper hose at a Minimum as its really Bad and probably alot older than Im thinking and really Soft
I am just wondering if the radiator could be pluged up causing some of this
Or anything else I should check into????
Thanks for your Imput
New thermostat
New Water Pump
i'd have to agree the rubber breaks down after age and certain conditions depending on what anti freeze is being used also . but if your temp.isnt running hot the themastat is working . i'd do a flush, replace hoses ,themastat and fluid then youll be ready to roll . also check you overflow bottle and make sure everything hooked up right . good luck
Two thoughts come to mind. The upper hose is the outlet from the block, heading into the radiator. The lower feeds coolant to the water pump, and thence to the block, heads, etc. If you are getting collapsed hoses, the lower is the more likely to collapse, and the upper should be under pressure from the block, pushing coolant into the radiator.
Unless the coolant level is significantly low, you should never have a collapsed hose where it is the outlet, under pressure, from the block & cooling passages.
Ain't spozta happen.
In many applications, the lower hose actually has a spring inside, used a reinforcement prevent the hose from collapsing. If the system has been kept maintenance-free, as in the coolant is just rusty water, the spring can rust away, and allow the hose to collapse.
I do not know how the upper hose can collapse unless there is no coolant in the system, or the thermostat is plugged, or, even the outlet from the intake behind the thermostat.
tom
tom
tom
tom
Ya Im thinking the same as you about the Lower sohould be the one to Collapse First
But its Not IDK why?? Coolant leval is Good
I wondered about Blockage too
All the Coolant is less than a year old BUT it just had the water pump and thermostat changed
SO Before this^^I bet it had been ALONG Time since coolant got changed if Ever
You mention the spring to keep the Hoses from colapsing I have been trying to think of something I could do to keep this from happening. Id put a spring in I just dont know where to find it
I think the best thing is Still plan to change Both Hoses later today or tommorrow
maybe I should flush the cooling system too
Do you guys just use that VC-9 Cleaner from Ford???
I know theres the prestone stuff I used on my car last year IDK how well that stuff worked
I have used the VC-9 cleaner on my big truck and it worked Great
f15olandscape
03-19-2013 11:15 PM
luke_trash
19
03-08-2005 02:09 PM
