1996 Clutch/brake pedal Bracket
1st thing i would check is the fluid level in your clutch master cylinder, 2nd need to check the clutch pedal with your hand and see how much play you have at the top before you feel it engaging and while your checking that you need to look at the pivot point on the bracket that your clutch and brake pedals rotate on. need to look close on the clutch side of the bracket and report back with finding please
I added brake fluid to the smaller reservoir next to the master cylinder. It said something like "add fluid to the step". It was empty or close to it. I put about 1 inch worth in it.
I looked at the pedal pivot bracket and mine doesn't look worn. I saw the photos you posted.
There is some play in the pedal. The pedal doesn't come all the way back like you think it would, When the pedal is pushed to the floor there is 3 inches of play before I hit the friction zone (clutch grabs) when releasing it.
I will add that I have a brake line leak back next to the pumpkin, where the hard line that runs in the frame meets up with the rubber line that goes to the splitter on top of the pumpkin.
I just put all new brakes and parking brake cables on the rear today, still have the line to repair. I hate brake lines!!! Would the lack of pressure in the brake system cause problems with the clutch slave cylinder?
I don't understand this, I test drove it yesterday and it ran fine. I get home and drive another 30 miles and I can't get it into gear. If I turn the truck off I can put it into any gear easy as pie. Start it up and no go....
Thanks for your time.
I didn't check the level in the tranny. didn't get a hose set up to put any in. I wasn't going to check it, I just was going to try adding mercon.
I did buy a manual today and I followed it to a T for bleeding the clutch master/slave cylinder. I opened the bleeder, (it was wobbly, like it is on an extension or something, is that normal?) Then I added fluid and let it run out the bleeder until no air came out. Then i shut it and had my son press the clutch in, hold it, I opened bleeder until it stopped flowing, then closed it up and pumped the clutch 5 times a few seconds apart.
Man, it went like the book said. We crossed our fingers and the truck started and NOTHING, it wouldn't go into any gear.
I shut it off, put truck in reverse, started it and it jerked and started cruising in reverse. I almost hit two of other cars in the driveway!!! Clutch would not release.
So after bleeding the master cylinder the clutch seems worse... Ideas?
Thanks for your help guys.
Hard Shifting:
Inspect the fluid level in the clutch master cylinder resiervoir
Is the fluid with the MAX and MIN level marks
If no add the brake fluid and check for leaks
If yes: With the engine off
Depress the clutch pedal
Shift the transmission
Does the transmission shift smoothly?
If no Inspect the fluid level in the transmission
Is the fluid level at the specified level?
If no FILL the transmission to specified level
If yes Check the transmission top cover by:
Remove the transmission
Remove the top cover
Shift the transmission through all gears
Does the top cover shift smoothly?
If no REPAIR and REPLACE the top cover as necessary
If yes then check Transmission Internal Components by:
Visually inspect the internal transmission components for indications of excessive wear or damage, REPAIR and REPLACE as needed.
I bought a haynes manual. It said to bleed it while it is in the vehicle.
It said to open the bleeder and let gravity flow the fluid through the system, then depress pedal and bleed again...yada yada
Is that why they sell the new master and slave combo units "prefilled". Wonder why the manual and another website give instructions to do it on the vehicle. A friend said to use a small pump and pump the fluid through the system while on the vehicle.
The transmission shifts fine when the vehicle is turned off.
I have brake fluid everywhere now, there is no checking for leaks, I didn't get a tube on the bleeder so I just let it run out, all over!!
If I remove tranny to bleed system I am replacing everything in it, master/slave, clutch, plate and all... That's what I am trying to avoid right now.
Thanks, I'll try a few more times before I remove the tranny.
