Vacuum locking Hubs
Vacuum locking Hubs
Like to start with love these forums ,have found MUCH needed info here and even more Helpful people.
I have a 2001 F-250 Super Duty Desiel Truck
Now to the question at hand. After extensive reading on here and checking my truck I'm 99.9% sure that I have a vacuum leak in the front wheel assembly. On both front wheels I have what looks like a seal flopping around between the knuckle joint and the hub assembly. Asuming this is a bad seal. Therefor causing my hubs to not engage and my inside blower to only go to defrost. After serveral minutes my blower will go back to dash or floor as set. Indicating vacuum has been restored after the solinoind has cycled,
So what I need is an exploded veiw of the wheel hub assembly for a reference during the repairs. I've already been guided to Guzzle's website with step by step instructions (which is wonderful), just hard to access in the garage with my hands covered in grease. So I would love an exploded veiw to help during repairs and to make sure I order all the needed seals and O-rings correctly the first time. I work out if this Truck so I need it back running ASAP.
Y2KW57
30
10-26-2020 11:33 PM
1966f250
10-11-2016 02:33 PM
Sawbones25
03-05-2008 10:36 PM
