Vacuum locking Hubs - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Vacuum locking Hubs
Old 12-07-2009, 11:41 PM
sledgehammer100 sledgehammer100 is offline
sledgehammer100 is starting off with a positive reputation.
Vacuum locking Hubs
Like to start with love these forums ,have found MUCH needed info here and even more Helpful people.
I have a 2001 F-250 Super Duty Desiel Truck
Now to the question at hand. After extensive reading on here and checking my truck I'm 99.9% sure that I have a vacuum leak in the front wheel assembly. On both front wheels I have what looks like a seal flopping around between the knuckle joint and the hub assembly. Asuming this is a bad seal. Therefor causing my hubs to not engage and my inside blower to only go to defrost. After serveral minutes my blower will go back to dash or floor as set. Indicating vacuum has been restored after the solinoind has cycled,
So what I need is an exploded veiw of the wheel hub assembly for a reference during the repairs. I've already been guided to Guzzle's website with step by step instructions (which is wonderful), just hard to access in the garage with my hands covered in grease. So I would love an exploded veiw to help during repairs and to make sure I order all the needed seals and O-rings correctly the first time. I work out if this Truck so I need it back running ASAP.
Old 12-08-2009, 12:40 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
That ring flopping around isn't your problem. Virtually all of these trucks have that ring just floating. No biggie at all.
That isn't the cause of your problem.
It may still turn out to be your seal, but the ring isn't the cause.
Pop
Old 12-08-2009, 05:21 PM
Turns out it was a cracked vacuum line, all fixed now. But still would like an exploded veiw of the hub assembly.
Old 04-22-2012, 09:10 AM
DarwinOz DarwinOz is offline
DarwinOz is starting off with a positive reputation.
Having the same problem with the vacuum hubs. Shall inspect the hoses again!!!!!!!!!
Good to know about the floppy rings.
Did you manage to obtain a exploded view of the front hub? That is what I was searching for when I found your comments.
Thank you for your input.
Old 04-22-2012, 09:14 AM
PA-Mark's Avatar
PA-Mark PA-Mark is offline
PA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputation
put it into the youtube search... bet you will find a few vids
Old 04-22-2012, 10:40 AM
Sand_Man's Avatar
Sand_Man Sand_Man is offline
Sand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud of
Yep, You Tube is my favorite how-to site. There's a video for EVERYTHING posted by people who really care enough to take the time to help out their fellow man. It's also a huge time-waster at work looking up vids on things like how to build a Gatling gun that shoots BB's...
66 rear wheel hub install help needed 1966f250 1961 - 1966 F-100 & Larger F-Series Trucks 3 10-11-2016 03:33 PM
Front end noise - inner seal dangling on stub shaft! Anyone exploded view HiZ Excursion - King of SUVs 9 07-18-2013 06:47 PM
front wheel hub assembly tfdcapt 1999 - 2003 7.3L Power Stroke Diesel 32 01-19-2013 02:55 PM
P1876 - How I got rid of it iron1951 1999 to 2016 Super Duty 0 10-17-2012 11:05 AM
2003 4x4 Excursion Front Hubs - Help DadsBig03 Excursion - King of SUVs 4 02-10-2011 08:52 PM
Tags
2003, 2008, 250, 73, assemby, diesel, f150, f250, f350, ford, forum, front, hub, hubs, lock, locking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
