slave cylinder life span
Old 12-07-2009, 09:55 PM
longpoleman's Avatar
longpoleman
longpoleman is offline
96 f150 300 4x4 5 speed.
does anyone know what the life span on a slave cylinder should be? i just replaced mine 1 year ago and it is out again.
Old 12-08-2009, 01:40 AM
88n94's Avatar
88n94
88n94 is offline
Should last longer than that. Did you remove the rubber cup(diaphram) from under the cap on the master cylinder and add brake fluid? Did you use a genuine Ford slave cylinder?
Old 12-08-2009, 06:03 AM
brown 4x4's Avatar
brown 4x4
brown 4x4 is offline
Ford has redesigned them so hopefully they'll last longer. My last one (old style from Ford) lasted about 110K miles/5 years. But I've seen them go out much sooner.
Old 12-08-2009, 08:34 AM
longpoleman
Yes when i bled it i removed the rubber piece to add fluid, i also about 3 months ago replaced the master cylinder also. no i didnt use an original ford part. i bought it from autozone. that may be the problem, cheap parts. this time i will buy it from the dealer.
Tom-N
Vendor Specials, Discounts, Product Announcements & Group Buys
12-30-2015 09:14 AM
Tom-N
10-13-2015 03:41 AM
Tom-N
10-13-2015 02:44 AM
mangymarmot
6.4L Power Stroke Diesel
10-10-2011 02:54 PM
jkidd_39
18
10-12-2010 11:31 PM
Quick Reply: slave cylinder life span
