What colors do I paint an engine for a 1965 F100 352? - Ford Truck Enthusiasts Forums
Old 12-07-2009, 09:40 PM
zepplyn zepplyn is offline
zepplyn is starting off with a positive reputation.
Help!! I need advice on the correct Original paint colors to paint a rebuilt 352 engine going into a 1965 F-100. From what I have gathered, it seems the original paint scheme was a Black block & intake manifold, with Gold valve covers. Any advice???
Old 12-07-2009, 10:16 PM
Bill W's Avatar
Bill W Bill W is offline
Bill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputation
when your done it should look like this. and Welcome to FTE
Old 12-07-2009, 10:38 PM
Bdox's Avatar
Bdox Bdox is offline
Iconoclast
Bdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputation
Welcome to FTE zep!
Old 12-08-2009, 03:45 AM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
block,heads, and rest of engine except valve covers are black...I think water pump and alt. mtg spacer is natural, valve covers are gold as shown in the pic in prior post...
- cs65
Old 12-08-2009, 09:28 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Welcome to FTE
You are 100% correct on the engine paint scheme.
However, if this was a 1966, the entire engine would be painted Ford Corporate Blue...including the valve covers.
1952/65 OHV I-6's and V8's: Ford painted the blocks one color, the valve covers another color.
The valve covers were painted specific colors, because...this is how Ford mechanics, outside repair shops, garages, body shops and etc. ID'd what sizes the engines were...I kid you not.
Every year, FoMoCo sent out to the dealers...charts showing the myriad valve cover paint colors, which showed what size engine each color represented.
The dealers then passed them out to all their wholesale accounts.
The problem was...the same engine in a car may/may not be painted the same as in a truck. Again, I kid you not.
Examples: 1965 F100/350 352: Black engine, Gold Valve Covers / 1965 Galaxie/LTD 352: Black engine, Blue Valve Covers.
1965 289 2V installed in Galaxies, Falcon's, Fairlanes, Mustangs: Black engine, Gold Valve Covers! (sigh)
Old 12-08-2009, 11:26 AM
civicmindeddogooder's Avatar
civicmindeddogooder civicmindeddogooder is offline
civicmindeddogooder is starting off with a positive reputation.
What about 240 ci? Color ofr 65 f-100
The color scheme interests me because my 240ci has never been changed and the block is black and the valve cover is black - the valve cover has a sticker which I can't read but would like to replace when I rebuild the engine (whenever that may be). Is this the proper color scheme for the 1965 240ci in a f100 2wd manual? If so, what did the sticker say and are replacements available? The sticker on the ac says 240 and 150hp.. Thanks.
Old 12-08-2009, 05:52 PM
Quote:
The block is black, but what color the valve cover is...I forget. It could be black, or blue, or red.
Old 12-08-2009, 06:01 PM
Bill W's Avatar
my 1965 240ci engine is also all Black.
Old 12-08-2009, 07:03 PM
Quote:
Here's the answer from Bill W(ilson) to y'all, and...to this Bill Wilson...who couldn't remember what color the valve cover was.
Old 12-08-2009, 07:30 PM
chaser1602 chaser1602 is offline
chaser1602 is starting off with a positive reputation.
The radiator should be silver?
Old 12-08-2009, 07:33 PM
Quote:
Hi-yo Silver away!
The radiator is supposed to be painted black.
Old 12-08-2009, 07:52 PM
yup...at that theres a special radiator paint...to stick to it...
- cs65
Old 12-08-2009, 08:00 PM
Bill W's Avatar
the rad does look silver in the picture... kind of... but it's not
Okay Squire Don, tell me what is special about the paint for a rad? high temp?
Old 12-08-2009, 09:07 PM
OldHarley's Avatar
OldHarley OldHarley is offline
OldHarley has a good reputation on FTE.OldHarley has a good reputation on FTE.OldHarley has a good reputation on FTE.
My '66 F100 Custom Cab 352 has a black block, heads, etc. Don't know about valve covers since they have been chromed.
Of course it may have been repainted or swapped at one time, but I suspect it might be due to an August 1965 build date.
Any ideas if it would be the proper color to leave black?
Old 12-08-2009, 11:28 PM
IsoGrifo's Avatar
IsoGrifo IsoGrifo is offline
IsoGrifo is starting off with a positive reputation.
I coulda sworn the 240 was black with blue valve covers...
F100 Gold 352 Engine Block manic-mike 1961 - 1966 F-100 & Larger F-Series Trucks 8 10-02-2016 07:23 AM
1966 f100 352 under the hood colors shayster72 1961 - 1966 F-100 & Larger F-Series Trucks 7 02-13-2016 10:46 PM
Hood Hinge Color sonny1965 1961 - 1966 F-100 & Larger F-Series Trucks 12 08-22-2015 11:37 PM
65 f600 fordman67 1961 - 1966 F-100 & Larger F-Series Trucks 30 08-17-2015 07:37 PM
Picture of original 1965 f100 352 ci air cleaner?? 2zwudz 1961 - 1966 F-100 & Larger F-Series Trucks 26 03-16-2015 07:07 PM
Tags
1965, 352, 65, color, colors, combinations, cover, engine, engines, f100, ford, gold, paint, rebuilt, schemes, trucks, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
