how to change the thermostat on a ford f-350 diesel 2003??? - Ford Truck Enthusiasts Forums
Old 12-07-2009, 07:18 PM
bjohnson bjohnson is offline
bjohnson is starting off with a positive reputation.
do anyone know where it is?
Old 12-07-2009, 07:20 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
ya follow the upper rad to hose to the engine at you will find it there.
Old 12-07-2009, 11:08 PM
03-6L-X's Avatar
03-6L-X 03-6L-X is offline
03-6L-X has a good reputation on FTE.03-6L-X has a good reputation on FTE.
69cj did a nice step by step on how to remove it.
Thermostat Removal Option: (Thank you 69cj)
A) Pull air cleaner assembly.
B) Drain coolant.
C) Remove upper radiator hose.
D) Remove 2 nuts on t-stat housing.
E) Lift and move press sensor bracket to the side. Not a lot of play in it but it will move.
F) Remove 2 more nuts on t-stat housing.
G) Remove housing. It will lift right off of the studs.
H) Reverse procedure to re-install. Use a new O ring (5 bucks at dealer). I used Vaseline to hold the O ring in place.
Old 01-06-2010, 05:55 PM
Jayson250's Avatar
Jayson250 Jayson250 is offline
Jayson250 is starting off with a positive reputation.
thermostat question
my ford 6.0l is running cool so would it be a thermostat problem it seems as tho its stuck open cuz there is a lil heat from dash but not much just wondering if thats the problem
Old 01-06-2010, 06:00 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Quote:
Could be, did you check the coolant level? Low coolant can cause heater to run cold.
Old 08-22-2010, 12:45 AM
Ed31 Ed31 is offline
Ed31 is starting off with a positive reputation.
Mine was running hot today pulling many long hills. I think it might be sticking closed, gonna change it out in the part store parking lot as I'm on vacation. If they don't have it would it be possible to run without it until I can get one in a different town?
Old 08-22-2010, 07:41 AM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is online now
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
Welcome to FTE bjohnson and Ed31 Be sure to check out our Tech Folder located at the top of the forum, enjoy your stay.
Old 08-22-2010, 08:31 AM
69cj's Avatar
Quote:
Not a good idea but if you have too you have too.
Old 12-06-2010, 11:14 AM
Jayybird Jayybird is offline
Jayybird is starting off with a positive reputation.
I am thinking about replacing my T-stat as well. I have about a 20 min commute in the morning to work 55/65 mph. My ECT's are holding at 178. That seems too low. I didn't really notice this back in the summer when its hot. I assume this due to the thermostat sticking. If i run it up to 75 mph and hold it there, ECTs run up to the upper 180s but not much more.
Also, I've noticed my fuel economy has dropped since I started noticing this....would that be a coincidence??...I assume not as the engine should be more efficinet once at operating temp.
Would yall recommend changing the t-stat for this one?
I've read seveal posts and these temps seem to be a little different for everyone. As for now and what i am basing my decision on is the ECTs should be 190-200 and EOT should be 200-210 under normal operating conditions without a load and should have a max of 15 degree difference between the two...anyone disagree with that.
Thanks
Old 12-06-2010, 12:56 PM
03-6L-X's Avatar
It's winter and every year about this time my mpg's go down. When the temperature does not get past 50*F during the day you cannot expect good mpg's.
Old 12-06-2010, 04:02 PM
mixerdrvr mixerdrvr is offline
mixerdrvr is starting off with a positive reputation.
Thanks
I have the same problem you have, only get to 174/176. Everything I have read says it is the thermostat getting weak/opening early. I am just waiting for a day in the upper 40s to get a chance to change it! may be next spring. it was 16 this morning!!!
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 12:40 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 10:21 PM
Tags
2003, 60, 60l, change, diesel, drain, f350, ford, installation, powerstroke, radiator, removal, replace, therastat, thermostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
