Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 12-07-2009, 05:24 PM
tazo's Avatar
tazo tazo is offline
Garage is empty, add now
tazo is gaining momentum as a positive member of FTE.
Question Biodiesel in a portable heater
I have a omni85 portable kerosene heater. I would like to burn biodiesel in it but, I an not sure how well it will work on a wick type of heater. Has anyone used b100 with any success in these types of heaters? Maybe a blend of b50 with kerosene? I would like to use biodiesel as an option to heat my house or when there are power outages.
__________________
2005 F350 6.0 lariat supercab 4x4 long bed zf6 speed and a real work horse--Burning B100 on nice days and B50 when there is a chill in the air
Mod's-BD exhaust brake-Dura flaps-Piaa back up lights-C-Betr mirrors
-Midwest short throw shifter-Splitz lift-Wilson cell antenna & Amp--Isspro ev gauges-fuel-pyro-ebp
1999 EB expedition (Wife's)
  #2 (permalink)
Old 12-08-2009, 03:03 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
I don't have any personal experience, but remember reading on another forum that it didn't work to well. If I was going to try it I would start out with a low mixture and upgrade from there.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 12-08-2009, 03:37 PM
FORD RANGER's Avatar
FORD RANGER FORD RANGER is offline
FORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud of
i'v had pretty good luck with the kerosun heaters diesel/premium gas yeah...
__________________
jack, slackmaster #6
1996 ford ranger xlt extended cab,2wd,4.0L v6,5spd,3.08 gears, tornado intake spacer, msd ignition,sun super tach2, k&n air filter, nascar oil filter.
iowa chapter member
  #4 (permalink)
Old 12-09-2009, 10:21 AM
tazo's Avatar
I tried straight b100 in the heater and it worked for about an hour and then the flame went out. I then added some kerosene to around a b20 blend and the heater will not relight. So I am getting a new wick since the one in there is old and will try it again. The only place I could find kerosene was $7.99 a gallon. Ouch! Biodiesel is $3.45 a gallon so I am just hoping that bio will work or at least a blend of bio. The heater burns around 1 gallon every 12-14 hours so the cheaper the fuel the more economical the cost would be.
__________________
  #5 (permalink)
Old 12-09-2009, 04:57 PM
1935 Ford pickup
I thought I'd red some things on this topic, so I went back and found these:
Re: [biofuel] BioDiesel in space heaters?
Home Heating with Biodiesel - BioHeat - General Biodiesel - BioDieselNow - Renewable biodiesel fuel
The problem seems to be that the wick won't handle the thicker diesel or biodiesel.
__________________
  #6 (permalink)
Old 12-09-2009, 05:00 PM
JaySVX's Avatar
JaySVX JaySVX is offline
2004 Ford Excursion
JaySVX has a very good reputation on FTE.JaySVX has a very good reputation on FTE.JaySVX has a very good reputation on FTE.JaySVX has a very good reputation on FTE.
I'd think it'd be easier to make your own test system if you don't want to contaminate your heater. Just get a wick from an oil lamp, a small pot, suspend the wick, and light. I think because of hte wax content it won't wick up to well, but who knows. I think it's to viscous to work as you might desire. At low temps, B100 can solidify, partially at least. Oil on the other hand just becomes viscous at lower temps. Now, an oil fired bullet heater might work..
__________________
2004 Ford Excursion 6.0
2001 Yamaha Roadstar 1600
1989 Porsche 944 w/400hp LS1
Quote:
Originally Posted by ncheavymetal View Post
But I have an excursion and don't concern myself with matters such as "how much does it weigh?"
  #7 (permalink)
Old 12-11-2009, 07:57 AM
Gun-Driver's Avatar
Gun-Driver Gun-Driver is offline
Gun-Driver is starting off with a positive reputation.
I used 100% Bio in tiki torches over the summer. The burned the wick down to fast.
Tags
biodiesel, bullet, burning, burns, cars, ford, heater, heaterbiodiesel, heaters, kerosene, oil, oregon, portable, protable, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
