any 57-60 with jag ifs???
i know it's a common clip in the earlier trucks but haven't been able to find any fridges with the jag clip in my search. is the jag not a good swap for the fridge? i know i've seen several done with camaro clips. if my info is correct the jag is almost perfect trackwidth wise i think a 1/2" narrower even which i'd really like something 1-3" narrower.
is there a better alternative? i'm knee deep in looking for the base for this project now. theres several possible in the area and i should have one home in the next coupla weeks...ken....
I believe that your frame is similar in the front to the 53-56 trucks, i.e. 34" wide outside of rail to outside of rail. Others have done it on the 53-56 (they are 34" wide). The 48-52 frame is pinched down in the front to 32". With the wider rails, you will need to either cut into the frame or cut into the Jag crossmember. It is a little bit more work than for 48-52. Others have done it. Holmseys website has good pix and info on how he did it.
