88 F350 Fuel Pump or Ignition??????
Old 12-07-2009, 10:58 PM
GooseKiller64's Avatar
GooseKiller64
GooseKiller64 is offline
Thanks bill, I'll do that first thing in the a.m. I'll let ya know what i come up with. I thought i figured out thats what was causing the fuel to be pumped to the front tank while running on the back one (fom your previous posts) That's why i thought maybe they are both not working. I'll check it out!
Old 12-10-2009, 07:28 PM
GooseKiller64
Just an update, was busy with clients goose hunting. Finally got the codes read, all we got was code 12, (idle?) Did the test on the in tank pump as best i could for being 2 degrees outside, seems the reading i got only got to about 2 pounds of fuel pressure from the boost pump, heading out to change it right now, I'll let you know. That code 12 would'nt cause this would it?
Old 12-11-2009, 06:25 PM
GooseKiller64
Well that wasn't it, it might be even worse now. Idles fine but I can't even accellerate at all now and the tachs bouncing all over when you hit the throttle. Guess I'll start looking at ignition components at this point. Open to any ideas if anyone has some.
Old 12-12-2009, 07:45 AM
subford's Avatar
subford
subford is offline
Could be something in the ignition system or the computer itself, hard to say.
Do you have parts you could sub out from another truck like yours?
I would go to a salvage yard and collect all of the parts and keep them on hand to sub out.
I keep a lot of them on hand for testing.
You would need a TFI module & distributor (for the PIP sensor) combo + ignition coil & computer.
Old 12-16-2009, 05:12 PM
GooseKiller64
Just an update, been busy again with goose hunters, finally figured out it is the selector valve. Now the the problem is price and availability. The dealer wants $195.00 and a 5 day wait! Does anyone know if there is aftermarket parts and maybe where to get them? Thanks for any info!!
Old 12-16-2009, 08:25 PM
Hitokori's Avatar
Hitokori
Hitokori is offline
lmc has them $130 for OE with quick connect fittings
$50 for universal with single wire connector
$80 for OE single wire conector
Old 12-16-2009, 08:32 PM
subford's Avatar
subford
subford is offline
There are no wires going to the selector valve.
Old 12-16-2009, 08:34 PM
Hitokori's Avatar
Hitokori
Hitokori is offline
uhm yea their is coz how else would it change tanks?
Old 12-16-2009, 08:50 PM
Hitokori's Avatar
Hitokori
Hitokori is offline
it really depends on the model truck mine has the big one under the driverside door area. the older models have an electric one that is kinda small looking
Old 12-16-2009, 09:03 PM
subford's Avatar
subford
subford is offline
Magic.
It changes tanks by the pressure put on the selector valve by the boost pump in the tank.
No wires.
Selector valve.
Old 12-16-2009, 09:11 PM
Hitokori's Avatar
Hitokori
Hitokori is offline
yea like i said if u read the other one... depends on model older ones are electric
Old 12-16-2009, 09:20 PM
GooseKiller64
Subford is correct, there are no wires connected to this unit. I was outside trying to bypass this thing to run off the front tank only but I'm afraid of splicing into the stock lines because they are so brittle. Heading into town to get fuel line in the a.m. Does anyone know if the stock lines with the quick connects are available or should i just change them out anyway?
  #28
Old 12-16-2009, 09:39 PM
Hitokori's Avatar
Hitokori
Hitokori is offline
<TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR vAlign=top align=left><TD class=tenptrdtxt width="34%" align=middle>
(Click Image To Enlarge) </TD><TD width="2%"> </TD><TD class=storeProdText>Electric Fuel Tank Selector Valve
For those looking for convenience, this electric tank switching valve is the ticket. Simply switch the fuel selector switch and your gauge and tanks switch automatically at the same time.
Fits the following Vehicles:
'66-'77 Ford Bronco
'73-'85 Ford Truck
SKU: 6188
Condition: New
Price: $39.00
</TD></TR></TBODY></TABLE>
these are electric i know the other kind arent
so now u going to say they dont have wires going to them.
it all goes back to me saying it depends on what madel u have
  #29
Old 12-16-2009, 10:04 PM
GooseKiller64
Wish they made a direct replacement for mine that was only $39.00 BUCKS!
  #30
Old 12-16-2009, 10:11 PM
GooseKiller64
Hey bill, ever heard of this being the only fuel filter on this year? ( selctor valve) There is no other filter anywhere inline?
Quick Reply: 88 F350 Fuel Pump or Ignition??????
