88 F350 Fuel Pump or Ignition?????? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 12-16-2009, 11:18 PM
Hitokori's Avatar
Hitokori Hitokori is offline
Hitokori is gaining momentum as a positive member of FTE.
<!-- BreadCrumbs are not required if we are coming through punchout --> ACDelco Fuel Tank Selector Valve
******** language=javascript type=text/javascript src="/wcsstore/CVB2BDirectStorefrontAssetStore/javascript/jquery.jqzoom.pack.js">*********>******** type=text/javascript> $(function() { var zoomOptions = { zoomWidth: 235, zoomHeight: 235, showEffect: 'fadein', fadeinSpeed: 'medium', hideEffect: 'fadeout', fadeoutSpeed: 'fast', title: false } $(".jqzoom").jqzoom(zoomOptions); }); *********>
<FORM id=addItems name=addItems action=OrderItemAdd cM1="7">
******** type=text/javascript> var pr_page_id='-49883718'; var pr_data_callback = function (info) { if (info.getFullReviewCount() > 0) { document.getElementById('hasReviews').style.displa y = "block";} else { document.getElementById('noReviews').style.display = "block";} }; POWERREVIEWS.display.prData (pr_data_callback); *********>
<!-- Start - JSP File Name: CatalogEntryPriceDisplay.jspf -->$134.89
<!-- End - JSP File Name: CatalogEntryPriceDisplay.jspf -->
ALL MAKES; 6 PORT MOTOR DRIVEN FUEL; USED WHERE RETURN LINES ARE REQUIRED, 12 VOLT @ 60 PSI MAX
this is one that advanced has
it looks nothing like whats on my truck but i dont guess u need the little filter that is garbage cause it leaks
</FORM>
  #32
Old 12-16-2009, 11:26 PM
GooseKiller64 GooseKiller64 is offline
GooseKiller64 is starting off with a positive reputation.
That does'nt look anything like mine.
  #33
Old 12-16-2009, 11:33 PM
Hitokori's Avatar
i know ur truck is the same year as mine so we both have the big fat round one... but thats the one that advance carries... thats the pic from their website.... and there should be a fuel filter further up the line towards the engine
  #34
Old 12-16-2009, 11:40 PM
I thought there was supposed to be one in front of the fuel pump on the frame rail but it is not there nor anywhere else. I'll be putting one inline tommorrow
  #35
Old 12-16-2009, 11:45 PM
Hitokori's Avatar
hmm mine has one where the frame kicks up at an angle u know where im talking about and it was on there from the factory.... well good luck and i hope u get all the kinks worked out
  #36
Old 12-17-2009, 07:10 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Quote:
Originally Posted by GooseKiller64 View Post
Hey bill, ever heard of this being the only fuel filter on this year? ( selctor valve) There is no other filter anywhere inline?
The 1986 only had the fuel filter in the selector valve but the 1988 should not have one in the selector valve and should have an inline filter mounted beside the high pressure fuel pump.
The fuel selector valves that "Hitokori" posted will not work. The first one is for for a Carburetor engine and the last one is for a Carburetor 460 or a Diesel engine.
Neither one has a Reservoir for the High Pressure Fuel Pump that is needed for the fuel injected engine.
No local auto parts store will have the right selector valve, You have to get it on the Internet or order it from a Ford dealer.
More information on the selector valve:
http://www.stangler.com/motorsports/...alve/index.htm
On the 88 the pump is on the left and the filter is on the right in the photo below.
  #37
Old 12-18-2009, 10:00 PM
Sorry for the delay, computer went haywire for a day. I bypassed the selector valve and it runs perfect!!!!!!!! We ended up finding it by hooking up a fuel pressure gauge and driving it down the road, it was at 40 psi till you hit the throttle and it went to 15 psi. I put an inline filter in and all should be ok for now. Thanks for all the input from everyone, espeacially bill (subford) you pointed me in the right direction. One more question though, can i put a manual valve on that or is it worth the money to replace it? (not sure if i trust putting another one in)
  #38
Old 12-18-2009, 11:00 PM
subford's Avatar
You need a Reservoir for the High Pressure Fuel Pump that is needed for the fuel injected engine.
It will run OK with out it except at WOT when you need the extra fuel.
Even the single tank trucks and Broncos have the non switching Reservoir.
If you do wire up a solenoid valve you will still need the booster pumps in the selected tank running for priming the high pressure pump and for going up hills.
Also you will have a return fuel problem as the solenoid valve does not have a select fuel route for the return fuel to the right tank.
  #39
Old 12-19-2009, 02:36 PM
Sounds like i better just put a new one in it, any suggestions on whre to purchase that? The dealer just seems way to expensive!!
  #40
Old 12-19-2009, 04:21 PM
subford's Avatar
Just an update, been busy again with goose hunters, finally figured out it is the selector valve. Now the the problem is price and availability. The dealer wants $195.00 and a 5 day wait! Does anyone know if there is aftermarket parts and maybe where to get them? Thanks for any info!!
How did you figured out it is the selector valve?
  #41
Old 12-19-2009, 04:33 PM
We hooked up a fuel pressure gauge and ran it outside the hood so we could monitor what it was doing while driving, when the pressure dropped from 40 to 15 psi when you stepped on the gas, we decided to bypass the selector valve just to make sure that was the problem (we had already replaced and checked the boost pumps & the high pressure pump for pressure)
  #42
Old 12-19-2009, 04:40 PM
subford's Avatar
I remember now you now you said that above.
Did you check to see if the boost pumps were running and had 5-8 PSI on the supply line from the tank?
Without this pressure the valve will not switch.
I think you said the valve had a filter in the bottom, did you replace it or do away with it if you put on an in line filter?
  #43
Old 12-19-2009, 05:00 PM
The boost pump (on the front tank- rear one isn't working) was checked and operating properly, I did not replace the filter in the selector valve, I just put one inline. I was told the odds of repairing the selector valve were pretty slim.
Looked at a 94 today..... chillman88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 08-09-2015 03:02 PM
at wits end, wondering if this truck is even fixable kedynskrow 1987 - 1996 F150 & Larger F-Series Trucks 16 11-11-2014 01:23 AM
Truck surges on start up welder41 1994.5 - 1997 7.3L Power Stroke Diesel 5 10-10-2014 10:06 PM
Idle surge but drives and starts perfect!!! f150light Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 09-26-2014 04:27 PM
glad to be a member scrobbie New Member Introductions 6 10-24-2013 10:59 PM
Tags
460, 87, 88, 94, f350, filter, ford, fuel, intermittent, problems, pump, replace, starting, surges, test, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
