Expedition 4x4 Problems - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 12-07-2009, 11:10 AM
brupp brupp is offline
brupp is starting off with a positive reputation.
I have a 98 Expedition EB 5.4L 4x4 Expedition that is having problems shifting into 4 wheel drive. When I move the 4x4 selection ****, the various 4 wheel drive lights don't come on in the dash. I know the lights work, because they light up when I first start the engine. Also, I don't hear or feel anything happening underneath by the transfer case.
A few months ago, I was able to shift into A4WD, but not 4H or 4L. Now, I can't shift into any of them.
I had this problem about 18 months ago right after the transfer case was rebuilt. Since it had just been in to the mechanic I took it back under warranty. The mechanic told me that all it needed was to be "reprogrammed," and they had it working in short order.
Is there any truth to having to "program" the 4 wheel drive? If so, how do I do this? Any other thoughts on what the problem might be and how I can diagnose/fix it?
Thanks in advance. I sure would like to have my 4 wheel drive back before the snow gets much deeper.
Old 12-07-2009, 11:26 AM
alloro alloro is online now
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
It's more likely that he reused the shift motor when he rebuilt the TC. Your whole problem sounds like a new shift motor will fix you right up.
Old 12-07-2009, 12:04 PM
Thanks. Is there a good way to test the shift motor? I would hate to replace it and have it not be the problem.
Old 12-07-2009, 05:04 PM
I don't know the pin-outs off hand, but I'm sure if you got under there you could see which wires go to the motor and probe those for power. Here's a write-up done for an Explorer, the Expedition is similar. This should give you a general idea of what to look for.
4X4 Shift Motor Rebuild - Ford Explorer Ranger Enthusiasts "Serious Explorations"®
Successful 2003 F150 King Ranch Automatic Transmission to 5 Speed Manual Transmission Conversion freebirdfreddy 1997 - 2003 F150 1 Today 11:23 AM
How to Troubleshoot and Fix F150 4X4 1997-2003 revytrucks 1997 - 2003 F150 124 12-31-2016 05:40 PM
2003 Expedition possible bad 4x4 control module? underdogl3 Expedition & Navigator 5 02-18-2016 08:00 PM
Transfer Case Shift Motor Question SteveCo 1999 to 2016 Super Duty 2 04-19-2015 10:20 AM
97 Expedition: Loud Xfer Case Noise/Vibration fpratt Clutch, Transmission, Differential, Axle & Transfer Case 1 10-21-2010 03:43 PM
Tags
1997, 4x4, 97, 98, drive, expedition, ford, light, motor, problems, replacement, shift, truck, wheel, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
