Air pump delete - Ford Truck Enthusiasts Forums
Air pump delete
Old 12-07-2009, 11:02 AM
97tugger 97tugger is offline
97tugger is starting off with a positive reputation.
Air pump delete
I was wondering if anyone had a Napa # for the shorter belt that is required to delete the air pump. The truck is a 97 250 with a 460. Also is there any other cheap external mods to make more power. I am installing headers and already have a cold air intake. And i don't want to put a cam in yet.
Old 12-08-2009, 06:51 AM
Jeff Dodson's Avatar
Jeff Dodson Jeff Dodson is offline
Jeff Dodson is starting off with a positive reputation.
I was thinking of removing my AIR injection pump.
Old 12-08-2009, 07:23 AM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
You may have to use a peice of string to measure for the belt , don't know much about 460s . Somethings we do to the SB is advance the timing a few deg , underdrive pulleys , E fans , change rocker arm ratio.....Lew
Old 12-08-2009, 10:06 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Air pump delete won't get you any power sorry, and if you don't also remove all the plumbing that was attached to it and plug where it attached to the exhaust you may create other problems. As stated timing advance and a full exhaust upgrade including headers is always good for some gains on these trucks.
Old 12-08-2009, 12:18 PM
I am installing L&L headers with plugs on them where it's suppost to go in. Also on the underdrive pulleys does this affect your AC or your cooling cause this truck likes to get hot in the summer and i don't want my AC to suck.
Old 12-08-2009, 12:35 PM
lew52's Avatar
I have been using underdrive pulleys for years & never had a problem with anything...
Old 12-08-2009, 02:06 PM
The problem is that big 460 takes a little more to cool than a sb. I think ford might have used the same radiator and it needs a bigger one. did you have cooling issues in the summer especially with ac on or idleing before the pulleys?
Old 12-08-2009, 02:20 PM
lew52's Avatar
Yeah make sure your radiator is flowing good & no clogs, check the fan clutch to , it may not be pulling enough air . When i did the underdrive pulleys on it made no difference to the cooling , never gets hot , i have an E fan to ....Lew
Old 12-08-2009, 02:41 PM
I'll have to check that but we have had this truck since it was new and as far as i can recall we have always had this problem.
Old 12-09-2009, 06:44 PM
Quote:
I wasnt thinking of removing it for peformance gains, as you probably remember about my SPARK KNOCK problem, I was looking over the fuel Injection site and it said something about the a faulty AIR INJECTION SYSTEM could cause it.
I have been ALL OVER THIS ENGINE looking for vacuum leaks and cannot find one. still no codes and I even RECHECKED the timing again and again. I did find one problem, the idel was to high. I figured it cant hurt to turn it down by the idle screw and it actually did some good, some of the LAG in it went away. I say LAG meaning the truck felt like something holding it back. Now I dont think it fixed it completely, it still dont run as strong as I think it should but better. I am thinking the Cable that goes from the throttle body to the tranny may also be a little out of adjustment and causing the tranny to shift to quickly and causing a load for the gear it should be and causing the spark knock. I have not had the opprotunityto check that, my son in law is driving the truck
Old 12-09-2009, 10:38 PM
capn kirk capn kirk is offline
capn kirk is gaining momentum as a positive member of FTE.
cant help with the issue on the fuel but for the easy performance upgrades cut the airhorns off the intake tubes
Old 12-09-2009, 11:06 PM
I made my own air intake that illiminated that whole plastic piece completley.
Old 12-09-2009, 11:09 PM
Hitokori's Avatar
Hitokori Hitokori is offline
Hitokori is gaining momentum as a positive member of FTE.
what air horn are u talking about? the one that goes up over the radiator like a snorkle
Old 12-10-2009, 02:05 AM
if you follow the two tubes that go from the air box to the throttle body there is a plastic pieces it looks like a set of binoculars. Its there to quiet down noise a little and provide i connection for the IAC, but to quiet down the noise it creates a venturi (downsizes pipe diameter) so by replacing it with a bigger constant diameter tube you gain some power. everyone fixes it their own way from a connecting tube to repiping it with pvc.
sorry bout the thread-jacking
Old 12-10-2009, 02:11 AM
its the plastic piece that looks like bioculars on the intake tubes between the airbox and throttle body. Its only there to quiet down the intake and give a place to hook up the iac. lose it and gain a little power
and i disconnected my AIR system- no problems
460 air pump delete - what belt?? Pilgrim 1987 - 1996 F150 & Larger F-Series Trucks 61 10-16-2016 11:28 AM
Smog pump gameover1974 Ford Inline Six, 200, 250, 4.9L / 300 3 01-06-2016 06:27 PM
4.9 smog delete Cdavis9 1987 - 1996 F150 & Larger F-Series Trucks 2 06-03-2015 12:36 PM
Will the smog pump change the A/F ratio the 02 sensor sees? Bad Bad Leroy Brown 1987 - 1996 F150 & Larger F-Series Trucks 6 06-03-2014 06:47 PM
delete 97puller Ford Truck Parts for Sale 15 04-08-2014 05:53 PM
Tags
1996, 49, 50, 89, air, belt, bypass, delete, f150, f250, ford, kit, pump, shorter, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
