finally test drove my overdrive
I took my truck out for the first time today with the spicer Aux. transmission. Let me just say WOW!!!!!!! What a diffrence it makes. 65mph on a smooth road is not even an issue!! The truck rides a little to rough to do that on a bad road but the rpms are so much more tollerable now at lower speeds. The gear noise is louder but I expected that due to the spur gears, but its not that bad. By far the best mod yet. Aside from new cab mounts. No vibrations the shifter is firm. I am really happy with the install I will try and get some pictures as soon as possible
yes its a .74 with a 2.00under and direct. I have not got the hang of shifting it without grinding gears however. Even double clutching its tough. I just leave it in OD and shift the main box, but i still want to get the hang of it. I wonder if mine is an early spicer as it has spicer and brown lipe on the id plate. I just sold a watson brown lipe with a flat top because it had a .85OD
F6Guy
I took a different approach on pictures. I started setting up albums vs. setting up the gallery. Working with the album seems to be easier to update, as well as to look through on others pages vs. galleries. I did a post not long ago on the subject (Albums vs Galleries) and feedback seemed mixed. Here's a link to it. I guess you can also get there by clicking on my profile page, then the stats tab.
Ford Truck Enthusiasts Forums - rb48f6's Albums
Mine is in the process of being torn down. One thing lead to another and there it goes! I had hoped to get the cab off before weather hit - no luck. Been getting hit with 30+mph wind and gusts pushing to 60. Right now it's 14 out - w/o windchill. Soon as weather breaks I'll get the cab off and frame in the garage.
kc7smo
17
09-20-2016 10:39 PM
