Dome Light Wiring
I'm not familiar with your kit, and I don't know how you have done your setup, but if it is a typical, OEM style installation, something commonly overlooked is the light assembly needs to be insulated from ground. The door switches and headlight switch will be the grounding source, allowing multiple "turn-on" locations. If the lamp itself is grounded, it will be on all the time.
Tee hee, they have a couple Chinese guys in the back room writing out there direction sheets so when you read them they will be consistant with all the other parts' instructions that are written over there for parts produced in China!
mrstephs
04-16-2016 08:13 AM
BLACKHAWK_1989
01-07-2016 09:42 PM
Busstom
11-06-2015 09:27 PM
Joe T.
11-08-2011 05:29 AM
