changing batteries on a diesel X - Ford Truck Enthusiasts Forums
Old 12-06-2009, 11:38 AM
Love Diesel X Love Diesel X is offline
Love Diesel X is starting off with a positive reputation.
Is there a preferred process when installing new batteries on the diesel to not lose the electronic settings?? keypad, radio, etc??
Thanx!
Old 12-06-2009, 11:41 AM
soutthpaw's Avatar
soutthpaw soutthpaw is offline
soutthpaw has a good reputation on FTE.soutthpaw has a good reputation on FTE.
as long as you only change one at a time and leave the other connected you wont loose your settings .. remember that the + side will be live the whole time so don t touch it to the chassis or metal parts
Old 12-06-2009, 11:47 AM
Thanx for the fast response
Old 12-06-2009, 07:13 PM
katiesdad7 katiesdad7 is offline
katiesdad7 is gaining momentum as a positive member of FTE.
Walmart batteries are good and cheap.
Old 12-10-2009, 10:35 AM
njstevens's Avatar
njstevens njstevens is offline
njstevens is starting off with a positive reputation.
Make sure you buy a quality set of batteries. Especially if you live somewhere it gets pretty cold. Takes a lot fo juice to egt the glow plugs gowing and to crank that diesel. I have alwasy believed you pay peanuts you will get monkeys when it comes to batteries.
Old 12-10-2009, 12:07 PM
psajunk's Avatar
psajunk psajunk is offline
psajunk is starting off with a positive reputation.
Mine too
170k miles on 2004 EB.
Looking at Optima yellow tops, Do I need to replace both together?
Dealer said only pass. side tested bad?
Thanks
Old 12-10-2009, 02:58 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
If you can afford it, rule of thumb is to replace both at same time.
Stewart
Old 12-10-2009, 03:21 PM
Downriver Thunder's Avatar
Downriver Thunder Downriver Thunder is offline
Downriver Thunder is starting off with a positive reputation.
Odyssey PC1750T
Try these, pricey but awesome. Also, when I changed the battery in my 250 I never lost any settings on the keypad or radio but radio is stock. Just had to reset time which is no biggy.
Old 12-11-2009, 09:06 AM
m350 m350 is offline
m350 is gaining momentum as a positive member of FTE.
Last yr,,,October or so,,my 06' F-350 six-O,,,had a sluggish start when getting cold,,,checked batteries,,,Pass side,,battery was toast,,,Driverside was fine,,,so I just replaced the one battery,,,,,as of Now,1 yr plus later,,,driverside original battery still going strong ! I replaced the bad one with another MotorCraft original type 850 CCA I beleive. Good Luck!
I have heard of mixed opinion's on Optima Batteries,,,and one opinion was from a Store clerk ,,,where they Sell and see the returns of the Optima batteries ! Good Luck !
Old 12-11-2009, 02:24 PM
X-Hibition's Avatar
X-Hibition X-Hibition is offline
X-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to all
Eight years on the Optima in my Sub, and it is just now time to replace. I think I made out well.
And the preferred method for diesel battery swaps is to change both at the same time. Leaving a weaker, older battery in place will negatively (battery humor!!) impact the fresh, new one. You own a diesel, spend the money.
Old 12-11-2009, 04:18 PM
Stewart_H's Avatar
Quote:
Originally Posted by Downriver Thunder View Post
Odyssey PC1750T
$265 for one battery! Pricey is an understatement!
In a cost vs. cost scenerio, unless they can guarantee that battery will last AT LEAST 12 years, there's no way it's worth it for a normal, everyday driven vehicle with normal electrical demands.
Stewart
Old 12-13-2009, 01:31 PM
BigBlue15's Avatar
BigBlue15 BigBlue15 is offline
BigBlue15 is starting off with a positive reputation.
Just the same as you would never want to replace just one tire on the same axle you always want to replace both batteries. Ultimately the older battery will tax the newer one. Your best bet is to find a gasser and put your second still good battery in that rig. And just my opinion of course, had the yellow top optima batteries and i say leave em on the shelf. Running two MTP65 Interstates and they are treating me well so far.
Old 12-14-2009, 10:38 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
When the 05's batteries went south after 5 yrs, the Walmart replacements were an inexpensive and easy fix... $74 apiece and they swapped them out while I shopped
Sometimes paying more is just paying more
Which Battery for Power Source on Diesel stufarmer 1999 to 2016 Super Duty 24 01-08-2017 05:21 PM
97 Turbo Diesel 4x4 HD Battery Terminal Repair or Replace??? rich gill 1987 - 1996 F150 & Larger F-Series Trucks 9 07-19-2010 05:46 AM
Diesel dual battery question bigred66 1999 to 2016 Super Duty 4 05-23-2010 06:30 PM
Dual Batteries, how to Skaning1 2009 - 2014 F150 5 05-21-2010 06:03 PM
hooking up an amp esco24 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 11 10-24-2009 08:08 PM
Tags
2000, 2005, 4700, batteries, battery, change, diesel, excursion, f250, f350, ford, international, size, starts, t444e
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
