Coolant capacity 1999 Explorer? - Ford Truck Enthusiasts Forums
Old 12-05-2009, 07:20 PM
vancouverpower vancouverpower is offline
vancouverpower is starting off with a positive reputation.
Anybody know how much the cooling system holds in a 1999 Explorer?
I have searched all over and can't find any numbers. The person at the parts store said 15.8 QTS but that seemed a little high to me.
If it is almost 16 QTS (4 gallons) could I just drain and flush the entire system (run the engine with the heater on) several times until the water runs out clear.
Then add 2 gallons of straight coolant (because I have heard that the system can't be totally drained without pulling the block drains) and top off with water to get about a 50/50 mix.
Old 12-05-2009, 09:46 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
thats exactly what i do. did it on the F150 and Exp. I dont think you get all the water out after draining. Seems like after adding the coolant, i might add 1-1.5 gallons of water, but after checking the strength its in inthe 50-60% range = good.
Old 12-05-2009, 10:29 PM
scucci's Avatar
scucci scucci is offline
scucci is starting off with a positive reputation.
From the service manual:
Cooling System Capacity 15.1 Liters (16.0 Quarts)
Cap pressure 89-124 kPa (13-18 psi)
Thermostat Opening Temperature
Starts to Open 90C (194F)
Fully Open 99C (210F)
Old 12-06-2009, 12:03 AM
Thanks everybody, that's what I needed to know!
Old 12-06-2009, 04:20 AM
ukexplorer ukexplorer is offline
ukexplorer is starting off with a positive reputation.
Last time I changed my coolant in my 99 Ex 4.0 SOHC, after flushing, I put in a total of approx 4 litres of anti freeze and 3.5 liters of de-ionised water after burping. It is still full. My owners manual states the capacity to be 7.4 liters.
Old 12-06-2009, 10:30 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
No, because you are never supposed to put tap water into the system. Tap water contains minerals that react with the metal in the system and can plug up the heater core and radiator. Pure water is a poor electrolyte, so combined with the corrosion inhibitors of the antifreeze, the system stays in pristine condition. Minerals are required to make water into a good electrolyte. This results in electrical corrosion and galvanization of the metal parts.
Even though it seems a waste, premixed coolant is a bargain. It is pure mineral free water with the correct amount of coolant already in it. Unless you already have an RO system or a water still or some other readily available source of purified water, the premixed coolant is the way to go. Plus it is convenient, I always carry a gallon in my vehicle in case of an emergency.
Now you can use tap water to flush the system, but you should not leave any in there. So after flushing, the system, drain the water out. To get it all out, you will have to waste some antifreeze. The system should not need to be flushed unless the system has already been neglected. If you change the coolant every other year with pure water and antifreeze, the corrosion should be so minimal that it will just drain out with the old coolant.
Coolant / Anti Freeze questions SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 14 07-12-2014 06:28 PM
Coolant smithm31 1994.5 - 1997 7.3L Power Stroke Diesel 12 06-10-2013 10:57 PM
Radiator - 27.9 QUARTS! Really!!? aerocolorado 1997-2006 Expedition & Navigator 1 07-23-2012 03:26 AM
5.0 radiator capacity ? fonzie 1987 - 1996 F150 & Larger F-Series Trucks 1 12-05-2010 11:59 PM
coolant mix ratio question 2danglong 1999 - 2003 7.3L Power Stroke Diesel 11 06-08-2005 10:24 AM
Tags
1994, 1997, 1999, 2000, 2001, 2008, 99, antifreeze, capacities, capacity, coolant, explorer, fluid, ford, radiator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
