New Alternator and new battery wont charge or hold charge - Ford Truck Enthusiasts Forums
Old 12-05-2009, 10:11 AM
camsford camsford is offline
camsford is starting off with a positive reputation.
I have a 1999 Ford F-250 started off with battery going dead so checked alternator and battery and found out the alternaor was done so put in a new one and that didnt fix the problem so then figured new battery so tried that and also problem not solve so theirs a brand new alternator from ford and new mastercraft battery anyone know what could be wrong.
Old 12-05-2009, 12:16 PM
96f150's Avatar
96f150 96f150 is offline
96f150 is starting off with a positive reputation.
Did you check your Maxi-Fuses under the hood?
Old 12-05-2009, 01:12 PM
eallanboggs eallanboggs is offline
eallanboggs is starting off with a positive reputation.
Have you checked parasitic draw. It should be under 50mAmp once the modules fall asleep
Old 12-05-2009, 03:46 PM
ddelong ddelong is offline
ddelong is starting off with a positive reputation.
I just changed the alternator on my 99 Ford F150 and there are 3 connections to the alternator from the battery. One is an eyelet with a stud and nut and that would be easy. The other is a plug that cannot be placed incorrectly but the 3rd is a single wire connector. Maybe it is not connected???
The voltage regulator is integrated into the alternator so that couldn't be the culprit.
If it is not the cable connections, it could be in the cables from the alternator to the battery. One could be broken.
Old 12-05-2009, 05:42 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
charge the battery full.
measure the battery to be 12.8 volts
start the truck and measure the battery voltage to go up to 14 volts.
if it does, you battery is crap or you have a big electrical leak when motor is off.
if it dont charge 14 volts, then alternator is crap, or not connected.
Old 12-05-2009, 06:28 PM
pullenpoynt pullenpoynt is offline
pullenpoynt is starting off with a positive reputation.
have you cleaned your terminals so they are shiny and bright
Old 12-05-2009, 07:04 PM
Parasitic draw can be no higher than 50mAmp. As little as a few hundred mAmps will pull a fully charged batteries down in a few hours. If you've replaced the parts you say you have(some multiple times) you need to look for parasitic draw.
New alternator not charging batteries bluzzer 1999 to 2016 Super Duty 58 11-01-2016 11:43 AM
1983 F-150 Charging system Problems Ballerforlife911 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 02-18-2010 06:46 PM
F250 - 5.7L - Alternator or Charging issues CNG161 1999 to 2016 Super Duty 8 01-01-2010 12:26 PM
New Alternator and new battery wont charge or hold charge camsford 1999 to 2016 Super Duty 3 12-05-2009 11:30 AM
having trouble with charge from alternator to battery twowheledfreak 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 10-19-2004 07:21 PM
Tags
1997, 91, 99, alternater, alternator, alternators, battery, charge, charging, explorer, f150, ford, hold, problems, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
