Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 12-04-2009, 08:10 PM
desert sled desert sled is offline
Garage is empty, add now
desert sled is starting off with a positive reputation.
Fuel leak
I`m sure this is a very common question,but here goes. I have a fuel leak on my 2002 7.3. The leak appears to be in the area of the fuel filter,I say this because the valley appears top be getting wet with fuel and running down the back of the engine ( my driveway is inclined so it is obvious). The problem is worst on short trips and appears to go away quite a bit on my daily commute, which is about 35 miles of highway each way. What are the most common leak points and how hard are they to fix. Can a garage mechanic do these fixes. Please help cause this is my daily driver and i cant afford to have it in the shop. Thanks for a great foum.
  #2 (permalink)
Old 12-04-2009, 08:17 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
Sounds like a drain valve (yellow handle) on the back left passenger side of the bowl or it could be the fuel lines going into and out of the bowl, feel around with the motor on or at least the key on for wetness. Here's where to get the o-rings if you need them, Bob's top notch from service to delivery.. http://www.dieselorings.com/index.ph...by=DESCRIPTION
__________________
Mike's 03 F-250 7.3 CC SB XLT 4x4 Auto and just joined the 200,000 mile club and counting. PAA#26 Wife's: Whoops, I mean an 08 (Explorer) Eddie B. 4.0 v6 4x4 91,000 http://www.ford-trucks.com/forums/si...ic511779_3.gif
  #3 (permalink)
Old 12-04-2009, 11:25 PM
crazymut's Avatar
crazymut crazymut is offline
crazymut is gaining momentum as a positive member of FTE.crazymut is gaining momentum as a positive member of FTE.
Terry Horigan
Guzzels is another outlet for the orings, you can call Clay and he will set you up.
__________________
Terry
PAA #22 RHN Supporter
2001 F250 PSD, 4x4, auto, xcab, Power Slot rotors, Hawk pads, 6637 KWIK, Petes cover, 9007 Ultra Whites, , Bilsteins, 4in. MKO turbo back, DP TUNER, Isspro gauges, John Woods Trans, 168,000 miles
  #4 (permalink)
Old 12-05-2009, 07:17 AM
5280's Avatar
5280 5280 is offline
5280 is starting off with a positive reputation.
I would say it does sound like the bowl drain valve. I had the same symptoms on mine, it was was worse when it was cold. I think after you get a little heat under the hood the o-rings expand and the leaks are fewer. Anyway, I replaced mine with the blue o-rings from guzzle. You can down load PDF instructions from his website. It was fairly easy to do, even for a mechanical dummy like me. Replacement O-rings for Ford Diesel Engines
__________________
2000 Excursion. 7.3l PSD. Limited 2WD
  #5 (permalink)
Old 12-05-2009, 08:13 AM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
2002 Ford F-350
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
ChrisMPorras
I just ordered some blue o-rings from Guzzle last week just in case. Super fast delivery and order processing.
__________________
Chris
2002 F350 XLT, 7.3L CC 4x4, SRW, Autometer Ultralites, DP TUNER, BTS Trans, 6.0 tranny cooler, F650 dash, AIS w/zoodad, Warn Hubs, 4" MBRP exhaust, '08 rear end cover, Foil Delete, Heated Tow Mirrors, AIH Delete, Homemade CCV mod., Bilsteins.
The Silver Bullitt PAA# 24
Tags
03, 2002, 73, common, diesel, f250, filter, ford, fuel, fule, leak, leaks, leaky, powerstroke, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
