Vacuum pump pulley swap
this 6.9 vacuum pump has the old belt pulley system and I have an extra pulley from a 7.3 serpentine vacuum pump that seems to be the same from a 94.Does anyone know if it is possible to use a puller for the swap on these pulleys?basically going to take to old pulley and install on new vacuum pump.
The engine that is a 6.9 has the older belt system on it,have an extra vacuum pump from a newer (94) p/s that has the serpentine belt system.This vacuum pump is the same as the one on the 6.9 with the only difference is the pulleys.by simply removing the pulley that does not coincide with the belt system would be swapping out the pulley to the replaceing vacuum pump.
When the vac pump failed on my dad's 84, I had to pull the pulley off it as well. I had to modify the puller a little to get it under the collar. It was so far gone there was no salvage, just changing the diaphragm on it would not have fixed it...
Here is a pic of the pump I refer... 1992 - 1994 Ford E150/350 F150/350 Vacuum Pump:eBay Motors (item 220519802379 end time Dec-08-09 08:45:12 PST)
I know what you mean, mine is at a friend's yet, and the old man's is down to the farm... The alt pulley is held by a single nut. The old smog pumps are bolted, can't say i have seen a bolt on vac pump just yet. I had taken the pump off the parts truck to turn in for core when the old man's went south.
Where were you guys 2 days ago? check post 7 @ https://www.ford-trucks.com/forums/9...placement.html
farmall_7
05-18-2016 12:52 PM
bill macparker
11-19-2004 10:13 PM
