Ex towing receiver hardware?
#46
#47
Mark
#48
#49
#50
Bion,
But is sure is interesting that when we search the parts...I mean compare the two model years part by part...they are the SAME...kind of makes you scratch your head now doesn't it...
I hate giving out WRONG information...and I had always been led to beleive that the receiver mounting hardware had been changed to facilitate the weight upgrade...that doesn't seem to be a factually based position given our research looking at replacement parts now does it?
As an aside...the frames being different is interesting...not sure what to make of it...hopefully it means our 2005 frames are somewhat stronger and beefier in the rear which will accomodate the towing forces of my 1200# tongue weight better!
Thanks again for your diligence and time in looking...your data shows about the same as the schematics I posted above...and that is there does not appear to be any perceptible differences...at least not in the part number arena...and for petes sake...the drawings are both dated 11/16/1999 for the receiver...so that doesn't appear to be rev'd...but their configuration control may be more lax than what I am used to for my government customers!
Also...if ANYONE has any other information that could be useful in determining if there are REAL differences here...that we are missing...please share actual part numbers between the two model years so we can research it more!
Joe.
Joe.
It's possible that it makes perfect sense that the part numbers are now the same. When a part is backwards compatible, they just substitute the old part number for the new.
Example:
2000 has P/N ABC
2001-2005 has P/N XYZ
In 2001 they substituted ABC for XYZ assuming that it was a backwards compatible change like changing the bolt grade. ABC is no longer offered and anyone needing to replace it would buy XYZ.
#51
BUMP!!!
This is a great thread, I just learned quite a bit. Having an older Excursion I'm stuck with the 10,000 lb hitch, which may be a problem when I have my trailer all loaded up. So from everything I've read it looks like I need to upgrade my bolts.
Fortunately I'm within easy driving distance of Tousley Ford, and so I can go and pick up the required hardware easily. The one thing that concerns me is enlarging the holes, how do you guys recommend getting this done? Also is the fuel tank held on by the shield, or are there straps of some sort under there. Am I going to have this thing fall on me if I back the bolts out too far?
#53
BUMP!!!
Good luck. This looks like a lot of work.
#54
Search this. There was a thread on how to remove/replace the hitch platform. If I remember correctly, you just slide tank shield left/right to gain access. What is uncertain is how much room you will have for drill bit and/or motor. The 'nuts' are double-ganged together on oval plates that are fed in from frame end.
#55
Those will be some big drill bits! I took my receiver to a metal fab place nearby to have the holes enlarged. The holes in the Ex frame are already big enough. (I don't have the original receiver for mine, so the used one I picked up must be one of the early ones.)
#57
Hey Housedad can you email aq copy of that Ford Source Books to me, plz?
chrisandre33@gmail.com
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
12-06-2016 04:10 PM
wrvond
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
05-26-2016 10:56 PM
