Installing new radio in 79 F-250 - Ford Truck Enthusiasts Forums
Old 12-03-2009, 03:55 PM
TheDrewd TheDrewd is offline
TheDrewd is starting off with a positive reputation.
I am a new member and I just bought a 1979 F-250 Trailer Special.
I love it already. It seems to be in great condition, with some minor issues: fuel gauge at E / not working, temp gauge at H / shorted out?, ripped seat cover, missing hot and cold air ducts, a somewhat smashed up tailgate / still works, a small fuel leak that I think is coming form the disused rear fuel tank / front one is new, and a rough hot idle / doesn't die though. I sincerely hope that is all there is wrong with it for now.
All these issues I will be addressing in future posts, but I was wondering right off the bat about replacing the AM stereo with something so I can at least listen to FM radio, if not CDs if possible. I would like any one's opinion on how to do that well.
I used to drive a somewhat beat up 1995 F-250 for work, and that was just a rough beast compared to this smooth cat I have now. My dad and are also going to be fixing up a '67 F-250 for educational fun this winter. Digging the old Ford trucks right now.
Old 12-03-2009, 04:23 PM
Furyus1's Avatar
Furyus1 Furyus1 is offline
Furyus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputation
If you can find a twin-post FM stereo that will work in that spot, great...
Otherwise, you have to cut-off the lower half of the metal radio/temp control bracket (I don't know it's proper name) and cut a big hole in your dash bezel. I got lucky and found someone here that already had one cut-out so, I didn't have to mutilate my original pieces... May even find one in a junkyard that's already cut-out...
Or, you can try one of these:
FM Transmitters / Modulators
Old 12-03-2009, 04:43 PM
79FordBlake's Avatar
79FordBlake 79FordBlake is offline
79FordBlake is starting off with a positive reputation.
I wouldnt say you have to cut a big hole. Just trim out the one that is already there. Its pretty simple. Takes like an hour to get it ready for the new cd player to go in. I cut the plugs off of my old radio and used them to hook up the new cd player so I wouldnt have to cut anything from the wiring harness in the truck. Getting off your door panels to put in the speakers and run new wire will probably be what takes the most time.
Old 12-03-2009, 04:56 PM
I was going to mount the cd player under the dash but I decided to put it in the stock location. This is on my 73. The opening was already wide enough so no cuttin had to be done there. Didnt have to do any cuttin at the top either. The bottom had to be trimed slightly to remove the spots where the screws use to go to hold the bezel down(it still is securely in place and does not vibirate with just those two screws gone). I did this with a mini-hacksaw then filled it down smooth. The radio/heater control bracket was trimed to size with a cut-off wheel. You don't have to cut it in half, it will be pretty thin at the edges but you can reinforce it from the sides and make it strong. If you already have it planned out what you wanna do this is an hour job or less. I am goin to get something to cover up the small gap at the top of the cd player.
Old 12-03-2009, 05:40 PM
79_408_Clevor 79_408_Clevor is offline
79_408_Clevor is starting off with a positive reputation.
Here is mine. Took about an hour with my Dremel tool cutting the plastic took the longest and finishing it. I also painted it to match the interior when I had it out, as it adds a nice clean look. The metal brackets the original radio was mounted to didnt take very long actually. Some here who are purist will advise against doing such modifications but its your truck.
LMC and some other restoration parts suppliers also sell a 2 post design radio that looks very much like the originals that requires no modifications and allows a use of a seperate cd changer, but these are a bit more costly.
Old 12-03-2009, 09:11 PM
ol74hb ol74hb is offline
ol74hb is starting off with a positive reputation.
you can try custom autosound. looks good Ford-Lincoln-Merc- Radios
Old 12-03-2009, 09:35 PM
Greyman Greyman is offline
Greyman is starting off with a positive reputation.
Ditto on the Custom Autosound radio. I have one in my 78 f250. I think it was 139.00. No cutting perfect fit and great sound. Has a am radio look when off and when on it has a digital display that lights up behind the fake tuner face. You can also get one that will control a cd changer. Mine has an aux cable plug in in the back for an ipod, ran the wire thru the ashtray hole.
Old 12-03-2009, 09:57 PM
Tees77f150's Avatar
Tees77f150 Tees77f150 is offline
Tees77f150 is gaining momentum as a positive member of FTE.
Quote:
Does that aux cable plug also work for satellite radio?
Old 12-04-2009, 07:54 AM
Thanks
Thanks for the replies, this info will help a lot.
As the temp rises, the no start hot issue gets worse. sportsdad 1999 - 2003 7.3L Power Stroke Diesel 13 06-08-2014 06:06 AM
EXTREMELY STRANGE fuel gauge issue arockyway2go 1973 - 1979 F-100 & Larger F-Series Trucks 2 06-02-2014 01:01 AM
04 f-450 radio wiring problem jalowman 1999 to 2016 Super Duty 0 02-06-2014 03:44 PM
Cluster Issue firefighter15 1999 to 2016 Super Duty 0 12-15-2013 08:17 PM
Driver's Side Speaker Doesn't Work chemaholic 1973 - 1979 F-100 & Larger F-Series Trucks 14 05-10-2013 06:22 PM
Tags
250, 79, bracket, cd, dash, f100, f150, ford, install, mounting, player, put, radio, remove, stereo, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
