Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-03-2009, 10:52 AM
JamiN3-6 JamiN3-6 is offline
1991 Ford F-150
My Garage
JamiN3-6 is starting off with a positive reputation.
E-150 heater problems
Hey, here and looking forward to getting some good answers
The heater in my 1998 E-150 has not been working lately at all. There was one day a couple of weeks ago that it started working and it worked good for the day but by the next day it stopped. Where is the first place that i can start at to get this resolved?
Thanks in advance for any assistance!!
  #2 (permalink)
Old 12-03-2009, 01:23 PM
powersmoked's Avatar
powersmoked powersmoked is offline
Garage is empty, add now
powersmoked is gaining momentum as a positive member of FTE.
I don't own a e 150 but let me start for you. can you be more specific about what no heat means is the blower working, is your temp gauge working and does it show if the temp is normal. you should feel the rad and heater hoses and tell us what ones are hot. you should check that the coolant is full and air is purged out of coolant system. etc.
__________________
1999 Reg Cab, Styleside, 2.5L, 2WD, M5OD, RABS, no A/C, MFG. Date 12/98, Gatorback belt, Autolite DP plugs/wires, Fluids and Maintenance done regularly, 141k as of 5/2/2012
Unless you have gone to the control panel and created a detailed signature of your truck similar to mine you are not doing all you can to solve YOUR PROBLEM!
  #3 (permalink)
Old 12-03-2009, 01:26 PM
I just noticed you posted in the wrong forum you should probably repost in the correct one. and personally it helps me if you had a detailed profile like i do so i can see exactly what you have on your van and where you live for temperature reasons. welcome to the forum
__________________
  #4 (permalink)
Old 12-04-2009, 07:33 PM
1991 Ford F-150
My Garage
Ok, so i finally got my vehicals loaded and still trying to learn my way around.
Yes the blower is blowing and as far as i can tell the temp gauge is working. unfortunately it is too late to check the others and it is too cold right now. will check those tomorrow and let ya know.
Tags
150, 1998, 1999, 2003, box, common, e150, econoline, ford, heater, heating, heatnotworkingonmy1998e150van, problem, problems, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
