2005 6.0 Runs Bad when cold - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-03-2009, 12:29 AM
DGMFORD's Avatar
DGMFORD DGMFORD is offline
DGMFORD is gaining momentum as a positive member of FTE.DGMFORD is gaining momentum as a positive member of FTE.
Hi, I've been trying to figure out the problem with my 6.0 for some time now, when started in the morning and cold outside, the truck runs like crap, feels like it's running only on a couple cylinders. I have 97k on the truck, just got it back from Ford to have the EGR cooler and Oil Cooler replaced, was loosing water, I though that was the reason, seems like when I first got it back, it ran good, but it was still warm outside. It takes a good 5 to 10 minutes for it to really warm up and start running good. All other starts from that point are good unless it sits all day. Any suggestions? One last thing, if I plug it in and start it the next morning, runs like a top. Thanks
Old 12-03-2009, 12:42 AM
sandman1984 sandman1984 is offline
sandman1984 is starting off with a positive reputation.
It sounds like you have an injector or two going bad. Even just one injector can make it run pretty rough. You change your fuel filters enough?
Old 12-03-2009, 12:44 AM
DGMFORD's Avatar
I didn't think about the injectors, and no, I don't change then too often, as a matter of fact, it's been about a year now.
Old 12-03-2009, 10:26 AM
LSchicago2's Avatar
LSchicago2 LSchicago2 is offline
LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.
My 6.0 did that twice when I had it, it was injectors both times.
Old 12-03-2009, 11:49 AM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
If you hurry, that should be covered under warranty. 3k miles to go. Time to take it in for a thorough checkup before warranty ends.
Old 12-03-2009, 02:01 PM
krisbmeyer's Avatar
krisbmeyer krisbmeyer is offline
krisbmeyer is starting off with a positive reputation.
I had that problem also with the rough starts in cold weather. Ford replaced the FICM in my case but it still did not resolve the issue. It wasn't until i switched to 5w40 synthetic mobil 1 turbo diesel formula that my issue was resolved. The 15w40 had to high of a viscosity. And since you had the cooler etc. Replaced that means that ford drained and filled your trucks oil. What do you normally run in it?
Old 12-03-2009, 02:05 PM
krisbmeyer's Avatar
If you search the tech folders in this forum there are some videos of trucks with bad injectors. So you can compare that truck to yours before you take your truck into the dealer.
Old 12-04-2009, 11:14 AM
da94broncodude's Avatar
da94broncodude da94broncodude is offline
da94broncodude is starting off with a positive reputation.
injectors or ficm
Old 12-04-2009, 04:38 PM
Pro DIY Pro DIY is offline
Pro DIY is starting off with a positive reputation.
Check your oil level. My 7.3 will run like crap when it is cold and my oil level is low. Once the oil gets warm and expands it runs better. The fuel injectors are controlled by oil/oil pressure. So if oil is low they will not inject well or something like that. Hope this helps.
Old 12-04-2009, 06:31 PM
krisbmeyer's Avatar
Precisely why I said to check what oil your engine has in it. Ford would use the Motorcraft 15W40 which is to heavy for cold climates. There is even a TSB for the 6.0's regarding oil viscosity and ambient air temperature. And of course your it's also in either your owner's manual or your engine manual.
Old 12-04-2009, 08:52 PM
Dan Jordan's Avatar
Dan Jordan Dan Jordan is offline
Dan Jordan is starting off with a positive reputation.
before you spend to much. i had the same trouble with my 03 and it only needed to be reprogrammed under recall. if it is injectors they would be rough all the time. the oil could be it but maybe call the dealer first. i went in with the engine light on and they told me that first and fixed it before they took care of the engine light which was a sensor unrelated to the rough idle.
Old 12-04-2009, 08:54 PM
Lou Braun Lou Braun is offline
Lou Braun has a good reputation on FTE.Lou Braun has a good reputation on FTE.Lou Braun has a good reputation on FTE.
As bpounds mentioned, your truck is still under warranty. With only 3k miles to go, I'd hold off doing any experimenting to try fixing the problem yourself.
Let the dealer work on it while it is still on their dime.
Lou Braun
Old 12-04-2009, 10:09 PM
9228.bobcat's Avatar
9228.bobcat 9228.bobcat is offline
9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.
I have an 05' as well. I was running 15w40 in and it started up as rough as can be. Only had it in there for 400 miles and I switched to Rot 5w40 syn. It was like night and day. Just went and got the new flash as well. Just cranked it up this morning at 20 degrees and it ran as smooth as you can get. The new flash addresses the cold start issue. The 05' has a recall on the ebp sensor as well. If you haven't gotten that, you might want to . They will flash it for you then. Might want to consider it. Hope all works out for you. Later,Eric
Old 12-04-2009, 10:26 PM
krisbmeyer's Avatar
Quote:
Originally Posted by DGMFORD View Post
when started in the morning and cold outside, the truck runs like crap, seems like when I first got it back, it ran good, but it was still warm outside. It takes a good 5 to 10 minutes for it to really warm up and start running good. All other starts from that point are good unless it sits all day. One last thing, if I plug it in and start it the next morning, runs like a top.
So the truck starts good when it's warm out. If it's cold it has to warm up. And if it's plugged in all night it runs fine in the cold morning. Sounds like the oil is to heavy for the cold weather. So let me explain oil. Multi weight oils are made possible by adding polymers to oil. The polymers allow the oil to have different weights at different temperatures. The first number (15) indicates the viscosity of the oil at a cold temperature ( W= winter), while the second number indicates the viscosity at operating temperature (40). So if you're using 15W in your diesel in the cold and start your truck the oil is very thick like honey vs. 5W which will be thinner like water at cold start but once at operating temperature will still be 40weight just like the 15W40..... The viscosity rating is basically just the fluids resistance to flow.
Old 12-06-2009, 11:46 PM
DGMFORD's Avatar
Quote:
I've been running the 15/40 Motorcraft Diesel oil. It's interesting you mention about the oil, when I did my last oil change, it was several quarts low, the dealer changed it last when they did the egr cooler etc. I'm taking it in the morning to get it looked at
Problems - Cold Start/White Smoke: EGR Cooler, Oil Cooler, Injectors, FICM? karter81 6.0L Power Stroke Diesel 6 02-26-2016 03:23 PM
350 6.0 wont start when warm harley9823 6.0L Power Stroke Diesel 4 06-05-2015 01:16 AM
P0605 and P1668 AmericanMade 1999 - 2003 7.3L Power Stroke Diesel 7 12-25-2014 06:39 AM
My 6.0 is a slug when cold, even this time of year iron1951 6.0L Power Stroke Diesel 5 05-05-2014 08:38 PM
2003 F250 6.0 P0280, P2617, P0281 kevbits 6.0L Power Stroke Diesel 4 02-22-2014 10:09 AM
Tags
1999, 2000, 2003, 60, bad, cold, diesel, f150, f250, ford, idles, rough, ruff, run, runs, weather
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
