Battery Replacement BXT-65-650 - Ford Truck Enthusiasts Forums
Old 12-02-2009, 11:03 PM
smoketree smoketree is offline
smoketree is starting off with a positive reputation.
Question Battery Replacement BXT-65-650
My battery is going south on my 2005 King Ranch and I have not found a replacement that is maintenance free like the original BXT-65-650.
Sam's Club and Sears have batteries but I don't think I can put the original plastic cover back on over the caps. Ford manual says replace the plastic cover. I'm not sure why it's there, but it looks nice.
Any educated opinions on this.
Old 12-03-2009, 12:16 AM
Tylus's Avatar
Tylus Tylus is offline
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
I put an Interstate replacement with 850 CCA into my 2006 FX4.
worked just perfectly. I suggest you get a 700+ CCA battery. Bigger does equal better IMO when it comes to batteries. and you're only talking about a $20 difference at most
Old 12-03-2009, 05:52 AM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
bigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to behold
I guess at some point before I bought my 2005 it had a battery cover. It was missing by the time I took possession of the truck though. My 1997 had that cover and I ended up removing it, no ill effects on either truck. I would not worry about the battery being maintenance free or not, the cover should still fit, just a little looser.
Old 12-03-2009, 08:47 AM
Trouble I see is that with the non-maintenance free batteries you have to disconnect the cables when you want to check the battery fluid.
Old 12-03-2009, 08:50 AM
To check fluid you have to remove the cover. This means disconnecting the cables.
Old 12-03-2009, 10:32 AM
2004 xlt 5.4's Avatar
2004 xlt 5.4 2004 xlt 5.4 is offline
2004 xlt 5.4 is starting off with a positive reputation.
Got my battery upgraded to 850 CCA got ford battery $120 always had good luck and 4-5 years out of them.and maint. free.
Old 12-03-2009, 06:25 PM
aquaman aquaman is offline
aquaman is gaining momentum as a positive member of FTE.aquaman is gaining momentum as a positive member of FTE.
I recently replaced my stock battery about a month ago with a Kirkland from Costco. $72 if I remember right. 1000CCA. The one listed for our truck in the fitment guide is of a smaller battery but has a few more CCA's than stock spec; it costs $49. I got the bigger one and it fits perfectly.
3yr guaranteed replacement warranty, 100month prorated
It's manufactured by Johnson Controls--they're among the best in the industry.
I'm not sure what the plastic battery cover does, it fits with the new battery, but I left it off.
Old 12-03-2009, 07:58 PM
SMok SMok is offline
SMok is starting off with a positive reputation.
That cover is mostly for looks in my opinion, throw it away.
Old 06-22-2010, 11:55 AM
Sputz Sputz is offline
Sputz is starting off with a positive reputation.
I read somewhere that the plastic battery cover is to protect electronic components under the hood from the corrosion that will be caused by battery acid vapors - also to protect the battery from high heat in the engine compartment--
Old 06-23-2010, 10:43 AM
azchris's Avatar
azchris azchris is offline
azchris is starting off with a positive reputation.
Optima Batteries
I am switching all my vehicles to Optima batteries. They are a little bit more in cost but you do not have the acid vapor corrosion that you do with the liquid filled batteries. Even the maintenance free ones still off gas and corrode the wire connectors.
07 Mustang gt/cs
05 F-150 Lariet
Battery recommendations for 1986 F-150 5.0 EFI Freaksh0w 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 03-08-2017 01:41 PM
'86 F150 302- Which Battery? D Harry 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 03-06-2017 09:31 AM
Motorcraft battery bxt 65-850 Magnolia Tom 6.0L Power Stroke Diesel 11 03-17-2016 05:46 PM
New batteries fgallant 6.0L Power Stroke Diesel 31 12-01-2009 07:33 PM
Battery drain Bruce S 6.0L Power Stroke Diesel 8 08-01-2007 04:08 PM
Tags
65, 650, 65650, batteries, battery, bxt, bxt65650, f150, ford, king, manual, motorcraft, ranch, replacement, shop, specs, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
