Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 12-02-2009, 09:55 PM
bg2 bg2 is offline
bg2 is starting off with a positive reputation.
1948 F4
Hello-
New here-I came across a 1948 F4 advertised as a 100 HP flathead V8 with a four speed with a granny low.
Not sure what its condition is yet-I am interested in it to use to haul a small antique dozer weighing about 7.5 tons. I am looking for the smallest trailer I can put it on.
Any thoughts or experience on this would be helpful. Too small? My idea is to use it and do restoration a little at a time while using it.
Thanks-Good comments on this board.
  #2 (permalink)
Old 12-02-2009, 11:38 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has a good reputation on FTE. bobj49f2 has a good reputation on FTE.
First, welcome to the board.
7˝ tons is a little too much in my opinion to ask a truck like this to haul. I occasionally haul my '49 8N tractor behind my 3/4 F-2 for a short distances to local shows and it barely handles it. I don't know how these old trucks did in the '40 traffic but in today's traffic they are too slow some times empty. You also have to consider the braking on these old trucks. They're adequate for the truck and a fair load but hitch 7˝ tons behind it, and if you can reach a decent speed, you'll have a heck of time stopping that rig.
__________________
Old trucks, it's a sickness-one I hope they never find a cure for!
Bob Jones--Fat Fender Aficionado--
49 F-2 pickup/48 F-1 panel truck
48/51 F-4 flatbed (2 in 1)/49 8N tractor
www.fatfenderedtrucks.com
  #3 (permalink)
Old 12-03-2009, 12:21 AM
truckdog62563's Avatar
truckdog62563 truckdog62563 is offline
truckdog62563 has a good reputation on FTE. truckdog62563 has a good reputation on FTE.
Seems to me that you're asking a lot of that little truck. The GVWR of an F-4 is 10,000 lbs. of which about 5000 is the curb weight of the truck. I looked through my references but don't find whether the remaining 5000 lb. carrying payload would be the same amount that it could be expected to pull. A comparable modern truck could pull more than that, but maybe not the old one since it started life with only 100 h.p. and 180 lb.ft. of torque. A tired clutch and drive train might not even budge your 15,000 lb. dozer and trailer, much less allow it to be pulled at near highway speeds.
That then leads to discussion of "restoration a little at a time". Something you'd have to address as a first priority is its wheels. Just about every F-4/5/6 of the era came equipped with wheels that are today termed "widow makers". They are unserviceable and can be killers because the wheel halves can separate violently without warning. I'll include below links to old threads about them that have pictures to help you know whether they are what's on the truck. Stu
http://www.ford-trucks.com/forums/86...dowmakers.html
http://www.ford-trucks.com/forums/88...8-f-135-a.html
http://www.ford-trucks.com/forums/74...xperience.html
__________________
Stu
'52 F-3 Marmon-Herrington V-8
'52 F-3 Marmon-Herrington I-6
  #4 (permalink)
Old 12-03-2009, 05:45 AM
bg2 bg2 is offline
Thanks for the confirmation-I figured as much. I have seen pics from the day showing similar size trucks pulling dozers just a bit smaller. I thought maybe there were different tow packages set for the F4.
Appreciate the help-
  #5 (permalink)
Old 12-03-2009, 10:00 AM
Julies Cool F1's Avatar
Julies Cool F1 Julies Cool F1 is offline
Your Posting Princess!
1951 Ford F-100
Julies Cool F1 has a very good reputation on FTE. Julies Cool F1 has a very good reputation on FTE. Julies Cool F1 has a very good reputation on FTE.
I'm late (a usual) but Welcome to FTE!
__________________
Best wishes
Julie!
  #6 (permalink)
Old 12-03-2009, 10:28 AM
There were two options that would impact the F-4's towing/pulling ability. One was a choice of either a 5.14 or 5.83 rear axle ratio, the other a choice of dually or single rear wheel set up. The dually configuration had six 18" wheels that gave the 10,000 lb. GVWR. The other option was four 20" wheels that yielded a GVWR of 7,500 lbs. It was, however, common practice for F-4 owners to add the two extra 20" wheels on the rear to increase load capacity. But this wasn't a factory option, and like Bob said, the brakes and other suspension components weren't designed for it. Stu
__________________
Stu
  #7 (permalink)
Old 12-03-2009, 11:27 AM
bobj49f2's Avatar
You might have seen trucks that were a F-7 or F-8, those were the big boys of the day. Today they would be considered on part with maybe a F-600 series truck. F-5 and F-6 models were the same size physically as the F-4 but have beefier frame, double walled compared to the single wall of the F-4. The larger trucks also came with 2 speed rear axles as an option. F-4s were kind of like the Edsels of Ford trucks, kind of in the middle of two niches, they were too big for a small business to make economical deliveries and too small to do continuous heavy hauling. F-4 production numbers were the lowest of all models.
The reason I have a F-4 is because I wanted a dual wheeled truck but didn't want the added weight of the heavier frame and the rust problems that come with the double walled construction. You'd be hard pressed to find a F-5 of F-6 without major rust busting between the layers. I'll be able to drive my F-4, if I ever get it done, a little cheaper because of the light weight. I mainly bought it because I like the look of the bigger truck and to make medium deliveries for my business.
__________________
  #8 (permalink)
Old 12-03-2009, 05:53 PM
Fatboyd Fatboyd is offline
Fatboyd is starting off with a positive reputation.
I have a 2-speed differential with all the valving and hoses, and springs to go with it off a 51' F-6 if your interested !!
Tags
1948 , 1951 , curb , dually , empty , f4 , f5 , f6 , ford , panel , parts , restoration , size , truck , weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
