Gas tank capacity
also keep in mind i beelvie the factory sets the gauge to read EMPTY well before u actualy are...
in tank fuel pumps dont like to be run if not submerged in fuel.. running the tank to empty is hard on the pump, as it can cuase it to overheat..
so my guess is ur truck gauge reading is normal...
if u really wanna test it, bring along a jerrycan of gas and drive it till it runs out...
for what its worth when i let my tank get lower then normal for refilling it still never seems to take more then 24Gallons... i dont think ive ever been able to get near 29Gallons in it..
Gauge issue for sure. I have a 1/4 reading when in the 20-24 gal fill up. when trucks first came out someone tested when light comes on 6 gal left. I've tested farther than that by always reseting the trip meter but always use that as my base. When gas pump auto shut off can always depending on pump add an easy 5 gal more by running it slow. I've run low whole bunch of times. Tanks are rated at a certain temp and weight. The worst or the best depending how you look at it i put in 32 gal filling right up to the neck by drizzling it in
wildstang
26
09-18-2015 08:31 PM
overlandexpress
06-15-2013 08:29 AM
