Gas tank capacity - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Gas tank capacity
Old 12-02-2009, 05:07 PM
VAXB VAXB is offline
VAXB is starting off with a positive reputation.
Gas tank capacity
Easy question, I have a 2003 F250 super cab 6' bed 4x4 (v10 if that matters). My gauge says empty, then it only takes 18-20 gallons to fill it up. Does my truck really only have 20gal tank?
Old 12-02-2009, 05:09 PM
Rush117 Rush117 is offline
Rush117 has a good reputation on FTE.Rush117 has a good reputation on FTE.Rush117 has a good reputation on FTE.
Without going and looking, I believe it has a 29 gallon tank.
Old 12-02-2009, 05:24 PM
joe chevy's Avatar
joe chevy joe chevy is offline
joe chevy is gaining momentum as a positive member of FTE.
2004 short box - 29 gal , long box - 38 gal per owners manual
Old 12-02-2009, 10:05 PM
Thank you sirs, It would appear that I have a gauge issue.
Old 12-02-2009, 10:30 PM
Budman1962's Avatar
Budman1962 Budman1962 is online now
Budman1962 is starting off with a positive reputation.
Mine has done the same thing for a couple of years now. If you figure this out let us know.
Thanks,
Budman
Old 12-03-2009, 08:01 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
also keep in mind i beelvie the factory sets the gauge to read EMPTY well before u actualy are...
in tank fuel pumps dont like to be run if not submerged in fuel.. running the tank to empty is hard on the pump, as it can cuase it to overheat..
so my guess is ur truck gauge reading is normal...
if u really wanna test it, bring along a jerrycan of gas and drive it till it runs out...
for what its worth when i let my tank get lower then normal for refilling it still never seems to take more then 24Gallons... i dont think ive ever been able to get near 29Gallons in it..
Old 12-03-2009, 09:04 PM
kart11's Avatar
kart11 kart11 is offline
kart11 is starting off with a positive reputation.
My 99 seems hard to fill up, the pump shuts off early and I can usally get a few more gallons in it if I spend the time, but even when I think its completely full my gauge never reads full so I guess mine is the opposite of others.
Old 12-04-2009, 01:09 AM
FFD FFD is offline
FFD is starting off with a positive reputation.
Gauge issue for sure. I have a 1/4 reading when in the 20-24 gal fill up. when trucks first came out someone tested when light comes on 6 gal left. I've tested farther than that by always reseting the trip meter but always use that as my base. When gas pump auto shut off can always depending on pump add an easy 5 gal more by running it slow. I've run low whole bunch of times. Tanks are rated at a certain temp and weight. The worst or the best depending how you look at it i put in 32 gal filling right up to the neck by drizzling it in
Fuel tank capacity Bigdawg5565 Fuel Injection, Carburetion & Fuel System 1 09-25-2015 05:05 PM
did a fuel tank vent mod to front tank, mucho better wildstang 1994.5 - 1997 7.3L Power Stroke Diesel 26 09-18-2015 09:31 PM
stock fuel tank question longrange1971 6.7L Power Stroke Diesel 16 01-26-2015 10:37 PM
1996 Dual Tank Problem Big350 1987 - 1996 F150 & Larger F-Series Trucks 1 11-11-2013 12:31 PM
How To: tank and manual to electric tank switching valve overlandexpress 1973 - 1979 F-100 & Larger F-Series Trucks 5 06-15-2013 09:29 AM
Tags
04, 1972, 2001, 2003, 2004, cab, capacity, e250, f250, ford, fuel, gas, holds, size, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
