Picking an IN-Dash DVD Receiver. - Ford Truck Enthusiasts Forums
Old 12-02-2009, 01:40 PM
Jeremy2792 Jeremy2792 is offline
Jeremy2792 is starting off with a positive reputation.
I have a 2004 F-250 Crew Cab. I am in the market for an In-Dash DVD Receiver. I can't take the stock in dash cd player system much longer. I have been doing research trying to figure out what ball park I would be spending depending on the system I get. I was checking out a few websites and when I select my vehicle NON of the indash systems fit at all. The 5.7" or 6.1" how do I figure out which system works for my truck. What indash system do you guys have in your truck? Pros and Cons? Recommendations?
I am basically looking for a touch screen [with a volume ****] capable of playing my iPod, DVDs, CD's, etc. I wouldn't mind having a back up camera, but I would be adding that later down the road so it's not 100% necessary. I am looking to spend right at or around $500.
Thanks for all of your help,
-Jeremy.
Old 12-02-2009, 02:11 PM
Enough Already Enough Already is offline
Enough Already is starting off with a positive reputation.
Use crutchfield.com to look at all of the options and research for your specific vehicle. I recently purchased the Pioneer AVH-P4100DVD which basically has or can be attached to anything except for navigation. I'm loving it - but also upgraded my speakers, added an amp and sub and added a Boyo backup cam plus steering wheel control integration module. There is also an electronics sub-forum here you should check for more specific info.
Old 12-02-2009, 03:00 PM
I have been using Clutchfield it is even saying the Pioneer AVH0P4100DVD doesn't fit either. Which truck do you have? How do you like the radio without a physical **** to turn it up/down?
Old 12-02-2009, 06:03 PM
KRDiesel's Avatar
KRDiesel KRDiesel is offline
KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.
I have a Pioneer AVIC-D3, it took some minor triming but looks great.
Old 12-02-2009, 06:55 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
If you want to go ghetto, there are tons of OEM Ford stuff at the local junk yard, or at stereo dealers where the owner discarded it in favor of a better unit.
Old 12-03-2009, 01:14 AM
BigRy's Avatar
BigRy BigRy is offline
BigRy is gaining momentum as a positive member of FTE.
Look into the Pioneer Double Din units, they all fit with an install kit, you might have to do some minor trimming, but unlikely. I have the F90BT and it does everything, touchscreen, IPOD, DVD, Nav, bluetooth, and rear camera. They upgraded to the new X910BT, but all they did was take the F90 and install an updated version. You can get F90 on Ebay for about 500.00 new. Or if your re4ally feeling like spending some cash, they have the ZX110 indash, it is a full 7" touchscreen TFT and the F90 is 5.7" touchscreen with volume ****. Hope this helps.....
Old 12-03-2009, 07:32 AM
truckpoor truckpoor is offline
truckpoor is starting off with a positive reputation.
Crutchfield doesn't consider it a double din because it may need minor trimming to fit. They don't want the hassle of people complaining because of 1/8 inch of trimming. But it will fit.
Old 12-03-2009, 07:56 AM
BigRy's Avatar
Very true, trust me it wont need trimming, it installs easily with the right dash kit.
Old 12-03-2009, 10:02 AM
jdunbar jdunbar is offline
jdunbar is starting off with a positive reputation.
i installed the Pioneer AVH0P4100DVD in my 2004 f250 crew cab 4x4. all i had to do is trim the top and bottom lip with a dremel. took 5 minutes once the dash was out. not bad at all and looks sweet! nice and flush. you will need to by the bracket kit and you just slide it in one click at a time until you like the way it looks.
Old 12-03-2009, 10:08 AM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud of
Pioneer Avic Z2 here and it fit without any modification, I just don't think you can get them anymore.
Old 12-03-2009, 11:04 AM
CombatMedicF-250's Avatar
CombatMedicF-250 CombatMedicF-250 is offline
CombatMedicF-250 is starting off with a positive reputation.
Careful of some of the AVIC 700 and 900 series. They run a windows operating system and can freeze up and do strange things. I have an AVIC 700 series and got hit with that issue. I had to send it in for replacement into Pioneer.
But like it said above...it fits nice and pretty in our dash!
Mike
Old 12-03-2009, 11:16 AM
rotun's Avatar
rotun rotun is offline
Reads ***** rules!
rotun has a good reputation on FTE.rotun has a good reputation on FTE.
Avic-D3 has 6.1 " screen and a volume *** and a remote. Crutchfield says they are discontinued though?
Old 12-03-2009, 11:20 AM
The AVIC Series is advancing so quickly. It's not gonna take long for most of the 2yo builds will be going away. It's a good series...but like alot of Windows based builds, some do have issues. Not all of them are like that...but when people have problems...they have problems with them.
AVIC411.com
Mike
Old 12-03-2009, 01:52 PM
BigPapi's Avatar
BigPapi BigPapi is offline
BigPapi is starting off with a positive reputation.
I have a panasonic unit in mine. I like it.
Screen comes out of the dash. DVD/Satellite/GPS
Was in the truck when I got it. Touchscreen w/remote.
Old 12-03-2009, 02:38 PM
KRDiesel's Avatar
Yep, the D3 has been replaced.
Installed a new entertainment unit in my 2012 F250 Ltngdrvr 1999 to 2016 Super Duty 0 09-11-2014 09:12 PM
IN-DASH NAVIGATION HELP! nick7.3 1999 - 2003 7.3L Power Stroke Diesel 2 02-07-2012 08:11 PM
iPod plug Ryeandwater Excursion - King of SUVs 36 09-28-2010 12:58 PM
F350 Lariat crew cab stock stereo size help nivek27 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 4 03-06-2010 05:20 PM
In-Dash NAV / What is Best Replacement for AVIC-D1? Forest Excursion - King of SUVs 9 12-07-2009 12:25 AM
Tags
2001, 2007, 99, back, camera, dash, dashdvd, dvd, f150, f250, fit, ford, player, reciever, specifications, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
