f550 stainless exhaust
Basically, with my work box on the back of the truck and the clearance issues between it and the fuel tank the only pipe that would fit is the factory 3.5 inch and it was tight.
What I ended up doing was exiting in front of the rear tire.
Not exactly what I wanted to end up doing because it is noisier in the cab of the truck that way, but I really didn't want the factory size exhaust either.
What I would recommend is getting whatever SS system you want and modding it so that it exits in front of the rear tire.
Or just go back to Ford and get thier system, it's semi stainless anyway.
Dan im glad u saw this since ur the resident 550 expert.
Id mod one if it was my truck but its a work truck and the only reason to go bigger was because aftermarket is cheaper.
Was the fuel tank or ur flatbed the culprit on the clearance issues? I as because our truck is a single cab dump built on the crew cab chassis. I believe the dump box is 12 feet long
Just not enough room to get the 5" pipe through there.
Dan, come on now, you can do it if you want to. I put a 5" on my 550 with a reg dually bed. you saw it. its tight but it can be done. just razzin ya! hope all is well in Seattle.
To the OP the only issue I had was the extended length of the 550 to a 350. i purchased an extra section of pipe and it fit fine.
Barney
Barney
carid
Vendor Specials, Discounts, Product Announcements & Group Buys
01-29-2016 02:30 AM
justinhip
2004 - 2008 F150
11-08-2015 05:48 AM
Pireaux
06-04-2015 12:43 PM
