First post: Looking for 1951 chrome grille
https://secure25.securewebsession.co...shop/index.htm
$550 plus a $200 core charge. probably not a bad deal?? I wonder what qualifies as a "Core" ? something perfect and dent free I suppose??
someone should call them and find out more details since I doubt you could have your perfect grill chromed for that price????
That doesn't seem like to bad a price to have one chromed, although I have never had anything chromed. Yet....
I have been in the process of organizing and cleaning the garage lately, I thought the only thing multiplying in my garage were Mice but apparently not!
I suppose I could part with one if someone is still looking.
Wait, did you say you have a 7, 5, & 3 tooth grills? thats exactly how many teeth I have on the wall, so you essentially had to use that many grills to get your custom ones setup. So yes, I guess you would be right, "you can never have too many Grills"
cheers
Josh
EDIT; here is a set of grill teeth just listed on Ebay today
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_500wt_1182
cheers
Josh
True!
I was actually able to find extra teeth on e-bay as well. I bought the two extra grilles and then two auctions with a set 3 teeth each.
With the full front tilt, I brazed the mounting bolts to the headlight buckets of each and wired them with the same quick disconnect electrical plug. So I can undo the wing nuts holding the grile on, drop it off the truck, and put one of the others on in about 5 minutes.
I didn't cut the valance to hold the extra teeth, but rather shaved them off to sit VERY close on top of it. That took a lot of patience and a good set of files.
I like the 5 tooth the best. But for every piece of my truck that I have customized, I have a 100% stock replacement that can be changed out easily - including the interior/dash.
Here's the grille pics again. The five tooth is in the post above on the truck. In this last picture note the hood up and the wing nuts behind the wind breaks holding on the grille (object in the front is the sun visor, and YES 4 Horns!):
They not only add teeth.... they chrome them...... I'm speechless.....
#30
Saw these on E-bay this morning:
Ford 1951 1952 pickup truck front grille ribs, set:eBay Motors (item 290383257318 end time Dec-26-09 12:57:37 PST)
Mixer man
04-30-2017 12:50 AM
jwhorsefolk
21
03-17-2017 07:18 PM
HILLBILLY BOB
07-30-2016 09:46 PM
sadlerbar
11-10-2015 10:20 AM
