I-Beam Flip?
Old 01-21-2010, 12:59 AM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
Originally Posted by NUTTY4X4
why dont you just straight axle ? even though why would you lift a 2wd its like lowering a 4wd
Not every off road truck is a rock crawling or trail truck - and not all off roaders need 4wd. Some of use are better drivers and can get just as many places with 2wd
Old 01-21-2010, 06:03 PM
bubbasinafordf150's Avatar
bubbasinafordf150
bubbasinafordf150 is offline
two wheel drives are funner off road cause it takes more skill to navigate the terrain, ive had 4wd and 2wd and outta both id run a 2wd off road any day, less mechanical breakage, more fun, and if you get stuck thats what a winch is for, a friend of mine swears by 2wds with 235s on the front and 33s on the back. i personally gotta agree with him ive only seen him get stuck one time and that was due to him slowing down when he should have gunned it. a 4wd drive may get through it quicker but with a 2wd you dont have to worrie about blowing the front diff out or snapping the front shaft.
Old 01-21-2010, 06:07 PM
Sayer Lane's Avatar
Sayer Lane
Sayer Lane is offline
Thank you finally somebody understands that just because you have a 2wd doesn't mean that it has to be a street machine. Mine never has been nor ever will. So thanks for someone finally speaking some truth about 2wds
Old 01-24-2010, 08:24 PM
93F22A6's Avatar
93F22A6
93F22A6 is offline
I think I'm just gonna try this and see how it goes. I don't drive my truck much and I'm pretty sure stock camber is 0, also to fix the caster I have to switch side correct?
Old 01-24-2010, 09:27 PM
ChaseTruck754
I'm not positive on the camber being 0 but it's worht a shot. As for the caster - yup you would have to flip the beam sides. The thing to worry about with this is the fact the end of one of the beams is jogged a bit to correct the offset front to back of the beam hangers.
Old 01-24-2010, 09:48 PM
93F22A6's Avatar
93F22A6
93F22A6 is offline
Well sh**, they will **** be inline (or should be) but it'll set the wheels forward or backwards.
Old 01-24-2010, 09:50 PM
ChaseTruck754
I'm not saying 100% that is won't work, but just have a GOOD look at your beams and all the bends, etc. before you get the thing too torn apart.
Old 01-24-2010, 09:56 PM
93F22A6's Avatar
93F22A6
93F22A6 is offline
I'll look tomorrow and see. That and get a rough est. on the lift amount.
Old 01-25-2010, 02:33 AM
bubbasinafordf150
i laid under my truck for about 2 hours the other day looking at this and from what i can tell both beams look like they both may bend back toward the rear wheels slightly but as far as flipping them i dont see it changing much besides the camber. some one on here said to take the truck after your done to a big rig shop and they can bend the beams slightly to fix your camber problem.
Old 01-25-2010, 11:24 AM
ChaseTruck754
If you're gonna do that why not just run a lift coil and have the big rig shop bend to correct the camber after that?
Old 01-25-2010, 03:29 PM
Metallheadd's Avatar
Metallheadd
Metallheadd is offline
Would that work? How much lift do you think one could have and still have it corrected?
Old 01-25-2010, 04:00 PM
ChaseTruck754
yes it would work. That's what lifts like the one from autofab are.
They can correct for whatever lift you want - but 5" of lift narrows the trackwidth 7/8" - and I wouldn't go much more than that.
  #28
Old 01-25-2010, 04:19 PM
Metallheadd
I am thinking that financially it may be better to just go with AutoFab kit. When you get lift springs, change out 33 yr old king pins and get beams bent for alignment, probably will be in the area of the $750 that the kit costs. Is this flawed thinking?
  #29
Old 01-25-2010, 04:23 PM
ChaseTruck754
If you are close enough by to do that then yeah. I assume you have looked at the prices on that stuff though - right?
Remember - you'll have a core charge for the beams and shipping this stuff is $$
  #30
Old 01-25-2010, 04:42 PM
Metallheadd
I've only gotten a few prices, such as I hear king pins are very expensive also very difficult to do at home. Just been reading alot of posts like these and trying to come up with something feasable.
Quick Reply: I-Beam Flip?
