1992 4.9 timing help please? - Ford Truck Enthusiasts Forums
Old 12-01-2009, 04:55 PM
cubnlizz cubnlizz is offline
cubnlizz is starting off with a positive reputation.
hi guys!
i could use some help here please..
have a 1992 f-150 300 inline 6.
i recently installed a used distributor, and decided to put a timing light on it to check.,
it seems to run ok, BUT is VERY hard to start in the COLD mornings, like it doesnt want to fire. otherwise seems to run fairly smooth, but terrible on gas!!
the ONLY way i can get the timing mark to appear in view of the timing plate, is when i put the timing light clip on the #3 wire??
now assuming that the #1 wire, is the wire right up front, i cannot even see the mark on the balancer no matter how much i turn the distributor, when clipped onto this wire.
did i maybe re-install the distributor a tooth -or -so off? and if so, will it still run ok? could this also be part of the gas hog problem?
thanks so much for any help.
Old 12-01-2009, 04:57 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
did you remove the spout when you used timing light?
Old 12-01-2009, 04:59 PM
thanks for the reply.
"the spout"? not sure what that is??
Old 12-01-2009, 06:35 PM
i found the spout, unplugged it, attached the timing clip lead to #1 and still do not see the mark anywhere in the location of timing mark plate.
Old 12-01-2009, 06:57 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
If you installed a distributor in it, the timing is definitely off. With the spout in or out, the timing pointer should be visible on the timing cover. Some 300's have two sets of timing marks - thank Ford for that - and you should be using the marks on the driver's side.
Another possibility is this. The balancer is made of two pieces of metal separated by a rubber ring. If the rubber deteriorates, the metal ring slips and the timing marks are all wrong. If you are using the right timing marks then your balancer has probably started to come apart. You can confirm this by moving the engine to TDC on the #1 cylinder and seeing where the timing mark is pointing. It should be close to zero.
You are using the #1 plug wire to time it, right?
Old 12-01-2009, 07:35 PM
timing issue
thanks for the reply:
the only way i can even get close to the timing marks, is when i use the # 3 plug wire!
when i attach it to the #1, i cannot even see the mark on the balancer, no matter how much i turn the dist. this tells me i maybe off by a tooth or so when i put the dist in??
Would really appreciate help. Start issue lawsonej 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 05-31-2016 07:40 AM
DSII timing help needed surf-SIX 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 01-02-2016 07:46 PM
Timing issues 400m *Please Help!* 64'F100BobbySurfer 1961 - 1966 F-100 & Larger F-Series Trucks 10 07-27-2015 06:56 AM
Setting Timing with HEI Distributor btacarlton 1973 - 1979 F-100 & Larger F-Series Trucks 28 04-17-2009 09:40 AM
head lights fade in and out tizzle 1978 - 1996 Big Bronco 7 12-19-2006 10:49 AM
Tags
150, 1989, 1992, 300, 49, 92, check, engines, f150, ford, liter, marks, procedure, specs, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
