You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Good job Jim.
Good morning.
I think we all just don't believe it is Dec. already.
__________________ Andy
2007, F350,6.0 PSD,4X4, Lariat, CC, DRW, SCT, Garrett Powermax, Banks turbo back, ARP's, ITP RR, Airdog II 130/75, Firestone air bags, Autometer gauges.
2002 Explorer 4.6 Eddie Bauer
"Whatever You Are Be a Good One". Abe Lincoln
__________________
Brian L.ask for facebook 230,000+miles
1994 F150 XL 2wd standard cab short bed 300 I6
E4OD trans 8.8 rear towing package with 3/4 ton springs linex bedliner safety rack cab guard
__________________
Is it December all ready? Good thing the plow is all ready to go.
__________________
Greg (aka Montana Heavenjugs)
2001 F250 XLT PSD CC SB - Tuned by Gearhead
6637 w/ Pete's cover; DashDaq; RR HPX, FRx; 5" MBRP SS turbo back; 6.0 IC and trans cooler; Retrax bed cover NorthEastSevenThrees <-- link to our homepage
__________________ Don #3 SlackMaster Chapter Leader of the Massachusetts Chapter
Join the MA Chapter Here Currently own: 2006 F350 Lariat CC Super Duty, 6.0 L Diesel FTE Fraternity OF Blue Max
__________________
Dave ~*~ Mods are listed in my Gallery (Updated 03/11/2010) Former Connecticut Chapter Leader Feb. 06, 2009 to Aug. 22, 2010.
2006 E35Q 6.0 5R110 35.4" Tires & 5.13 Diff., Unicell's Aerocell SRW body with Quigley 4x4 Conversion - - - 2004 Expedition XLT 5.4L 4X4 4R75W 3.73 Posi
Prior: Courier Pickup and a 1991 Crown Victoria Interceptor
Dave, Answers in order..
Yes you can get one for a regular strike, either single or with a second mortise for a deadbolt.
There is no rating for a jamb only. The jamb and door assembly may come with a UL tag affixed but you cannot modify it or it loses it's rating.
You will need to tell me what jamb depth (wall thickness) you want it for.
Do you want a flat slab, or an embossed door. If flat what gauge steel?
Aluminum threshold? Low profile (ADA)? Mill finish or anodized? Gold, bronze, etc....
Hinge size? Three 4" is basic, 4 1/2 or 5" for commercial and institutional doors.
I don't know if it will mate up to your existing door but I can get the hinge gain layout and you can measure what you have.
Hope this helps.
Jim:
Regular Strike plus deadbolt.
Hmm, I guess you are thinking of full thickness steel casing, but I'm not necessarily thinking similarly.
My vision is a narrow depth metal masonry frame to set in between the block walls.
I would set the door frame flush to the inside the basement face of the block and add trim to face off the exposed block between the storm door and this door.
The cinder block is about 7-3/4" thick but the studs above are only 2x4, so I guess I should fir out the studs so that the wall is a uniform thickness, which includes foam board over the blocks plus gypsum board over all that.
The gap between the blocks is a tad over 40-1/2."
Using the Therma-Tru rough masonry casing @39-25/32 that leaves just under 3/8" along either side, so I can form the gap & grout it in at the bottom and there is plenty of room to frame it back in at the top.
Embossed door, foam insulated.
Hmmm, I take it that the embossed door comes in one gauge only, by chance is the gauge 'commercial' i.e. heavier than Home Depot stuff.
Threshold ADA in mill finish, so I can roll stuff in & out.
Three four inch hinges.
__________________
Evening, all. Got my windows tinted this afternoon. Used Tint Masters on the Berlin Tpke.
I've yet to see it in the light and I can't roll down my windows for 2 days or clean them for 4 days. And they're all streaky from their squeegees. It's driving me nuts but I'm hoping it will be worth it.
I did legal tints on the sides (40%) and one shade darker (35%) on my rear window. I'm hoping it's dark enough for me but I didn't want to chance darker tints in Wallingford. Cops here got no real crime to stop so they just harass people about dumb crap.
