Can the 2 piece Spark plug be welded?
Old 11-30-2009, 10:47 PM
BII Plow Truck's Avatar
BII Plow Truck
BII Plow Truck is offline
Old 02-22-2010, 01:57 PM
BII Plow Truck
Anyone have any ideas?
Old 02-22-2010, 03:38 PM
greenego's Avatar
greenego
greenego is offline
Why would you even consider it when you can get a one piece sparkplug now for your application?
Old 02-22-2010, 05:25 PM
Peter94's Avatar
Peter94
Peter94 is offline
I'm sure you can probably weld it, whether or not it will still screw in and work afterwards is a different story...
Old 02-23-2010, 07:10 PM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
I wouldn't risk it....just buy the one piece plugs from champion.
Old 07-07-2011, 01:20 PM
BII Plow Truck
Champion ***SHIVER***
Rather do OEM Motorcraft or a good aftermarket like NGK or Bosch
Old 07-08-2011, 02:57 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
It sure can! How good are you at fine line tig welding??? I have done it to a lot of these plugs before the one piece came out. It takes about 3 mins a plug to do so it is time consuming but results in zero % failure rate later on!
Old 02-27-2013, 04:01 PM
BII Plow Truck
Sounds like you have a Niche business! You couldn't keep up with all the 5.4Ls out there!
Old 02-27-2013, 07:33 PM
ojai150's Avatar
ojai150
ojai150 is offline
you could probably get a stronger weld by removing the heads, and welding the shields on from the inside....
Old 03-02-2013, 06:00 AM
elrodalonzo's Avatar
elrodalonzo
elrodalonzo is offline
Don't waste all that time and money on that poorly designed garbage. Just put Champions in, I did 20K ago and the truck runs perfect. Problem solved for ever quick and easy.
svt2205
2004 - 2008 F150
37
12-11-2016 04:51 PM
svo121
Modular V8 (4.6L, 5.4L)
11-22-2010 09:44 PM
luvcycles 2
Modular V10 (6.8l)
06-04-2010 09:19 PM
Quick Reply: Can the 2 piece Spark plug be welded?
