Torqueshift in a 7.3?
Possible? Like Johnny said, anything's possible with enough money. But, let's review what you'd need to do:
1) Bellhousing adapter to make it bolt up to the 7.3 - not sure if these exist, it'd probably have to be custom made.
2) PCM that knows two things. One, how to control the Torqshift, and Two, how to control a 7.3 - THIS DOES NOT EXIST. I think you'd have to find an aftermarket Torqshift controller (which does exist), and a manual (stick) PCM for the 7.3.
It's not a simple bolt-in, and wire up.
Like Tex said, you're much better off getting a beafed-up 4R100 and just bolting it in.
Why do you want a torqshift?
If it's for durability, I'd suggest a built 4R100 done by one of the more reputable shops. If you want more gear ratios, maybe a Gear Vendors under/overdrive would be in order. $3,000 buys you another 4 ratios to use, and wouldn't require any custom computer work.
Gear Vendors under/overdrive transmissions the most awarded auxiliary transmissions.
awakening77
1999 to 2016 Super Duty
09-27-2016 12:53 PM
superduty1967
07-09-2014 06:26 AM
HD#1
08-05-2010 07:45 PM
1997, 73, adapter, bronco, conversion, ford, mate, ot, powerstroke, shift, torqshift, torque, torqueshift, v10, v10torqueshift
