1965 F-100 Vin Decode - Page 2 - Ford Truck Enthusiasts Forums
Old 04-29-2013, 10:59 PM
mongrot's Avatar
mongrot mongrot is offline
mongrot is starting off with a positive reputation.
Old 04-29-2013, 11:00 PM
mongrot's Avatar
Quote:
Originally Posted by BarnieTrk View Post
Look on the jam side of the driver's door, below the latch, there should be a Warranty Data Plate. Provide us with the information stamped there..... from that info, the information which you seek can be determined....if it's still the original equipment in it.
BarnieTrk
O.K, will do. The truck is 600 miles away & I won't see it until the end of May but will look at the plate when I'm there. It has all original drive-train, I know the original owner personally.
Old 06-15-2014, 05:06 PM
DDW66 DDW66 is offline
DDW66 is starting off with a positive reputation.
1965 Vin Decoding
Well, I can't seem to find a VIN decoder on line, and you guys seem to be a great resource. Can someone help me decode the following for a 65 F100?
Warranty# F10DR660229
WB 129
Color BM
Model F100
Body C87
Trans B
Axle A8
Also for the Block Tag:
352 65 5
5C 780J
Any and all help would be appreciated.
Old 06-15-2014, 09:04 PM
w5nra's Avatar
w5nra w5nra is offline
w5nra is starting off with a positive reputation.
WB 129
Color BM
Model F100
Body C87
Trans B
Axle A8
352 65 5
5C 780J
1965 Ford Truck VIN Decoder | vinmagic.com
Is one of them but you can't trust all the data on some of those sites. It looks like yours works but NumberDummy is the king of numbers.. haha
Yours must have been in the beginning of August and mine at the end... haha
F10DK710648
Old 06-16-2014, 12:31 PM
kjvforme's Avatar
kjvforme kjvforme is offline
kjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to all
WB 129
Color BM
Model F100
Body C87
Trans B
Axle A8
352 65 5
5C 780J
Double check your Body code, 87 was for the Econoline, should be C81. What was the DSO on the lower line of the Warranty plate?
Old 01-31-2015, 03:45 PM
Ford Guy 56 72 03 Ford Guy 56 72 03 is offline
Ford Guy 56 72 03 is starting off with a positive reputation.
Montana 1965 F-100 needs help also.
Hi Gentlemen,
I am new to this site and don't really know how to post my own statement so since I need the same help as this gentleman, I am going to tag along. I have bought a 1965 Ford F100 4x4 and I need help with the VIN/Warranty Number.
Here it is: F11DK592809.
What I think these numbers stand for:
F11= 61-66, 4 Wheel Drive, F-100
D= 1965, 352-V8, 2V-2 barrel carb, 208 hp, at 4400 rpm
K= Kansas City-assembly plant
592809= assemble date of Sept 1964
Please let me know how I did and what I have missed.
I am also interested in what the rest of the plate means.
Here it is:
W.B.120= Wheel Base of 120 inches
Color J= 65/66 Rangoon Red
Model F112= 63-66, 4 Wheel Drive, 5600 G.V.W., F-100
Body N81= No Idea - the 81A from 61-66 was a Standard Cab like mine
Trans N= No Idea - the F from 61-66 was 4 speed Manual like mine
Axle 08= 3:50 rear axle ratio 1965
Max G.V.W. LBS. 5600= Maximum Gross Vehicle Weight 5600 pounds
Cert. NET H.P. 172= 172 certified net horse power of 172 at 4000 rpm. Here I get confused as the 352 cid was suppose to be 208 hp at 4400 rpm
Is it due to the carb size?
R.P.M. 4000= revolutions per minute 4000 for testing horse power
D.S.O. 421298= distinguished service order- No Idea how to break down this number.
Thank you all in advance for any help given. Ford Guy 65 72 03
Old 01-31-2015, 04:45 PM
banjopicker66 banjopicker66 is offline
banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.
First of all, Welcome to FTE. You'll find a great deal of experience and knowledge here.
Second, I suggest you start a new thread when asking a question, rather than tacking onto an old one. It really helps keep the questions and topics organized!
Now, here is a little bit for you:
F11DK592809
F11 = F100 Series, 4x4
D = 352-V8, 2V-2 barrel carb, certified net horse power of 172 at 4000 rpm - no mention of any other measurement for trucks. Perhaps may be confused with specifications for cars with 352 engines?
K = Kansas City Assembly Plant
592809 = Sep '64, for '65 Model Year
N81 - The "N" stands for the color of interior trim, Red crush vinyl and red ladder woven plastic
81 = Conventional cab
Trans N = 4 speed New Process 435
Color J= Red (just red)
D.S.O. 421298 = District Special Order: 42 is for Fargo, the other 2, 2-digit numbers were for the dealer's use, were kept at the dealership that sold the truck, and are probably long lost.
Old 02-01-2015, 06:56 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
VIN: F11DK592809 / WB: 120 / COLOR: J / MODEL: F112 / BODY: N81 / TRANS: N / AXLE: 08 / MAX GVW LBS: 5600 / CERT NET HP: 172 / RPM: 4000 / DSO: 421298
I listed the above in the sequence they are stamped on the Warranty Plate.
Welcome to FTE
F11 = F100 4WD
D = 352 2V
K = Kansas City MO Assembly Plant.
592809 = 1965, assembled September 1964.
120" Wheelbase.
J = Rangoon Red.
F112 = F100 4WD, 5,600 lbs. GVWR
N81: N = Red Crush Vinyl & Red Ladder Pattern Woven Plastic / 81 = 81A Standard Cab.
N = New Process 435 4 Speed Manual Transmission.
08: Ford 9" Rear Axle / 3.50-1 / 3,300 lbs. Rear Axle Capacity.
5,600 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM (208 is the gross HP .. marked thus on air cleaner decal).
421298:
42 = Fargo ND Ford District Sales Office, where the original selling dealer ordered the truck from.
1298 = Domestic Special Order number. The truck was special ordered by the original purchaser, not "bought off the lot."
Domestic Special Order: Some type of special equipment that was not an RPO (Regular Production Order) was installed on this truck after it left the assembly line per the original purchasers order.
Could have been a special body (Flat or Stake Bed or Utility Body), or who knows...now, because the IDIOTS @ FoMoCo THREW AWAY all this info decades ago.
The dealers did not retain these codes, only the District Sales Offices did.
If the truck was in Moosepie WY and a parts problem occurred with the special equipment, the WY dealer contacted the Fargo ND District Sales Office passing along the 6 digit DSO
Fargo looked up the order, passed the info back to the dealer letting them know where the parts could be found.
Old 02-09-2015, 11:33 PM
Gentlemen,
Thank you very much for the info. It will be of great help.
Ford On
73 F700 vin decode DTB 73 F700 Large Truck 118 11-17-2016 03:01 PM
VIN Decode - 1965 jvettoretti 1961 - 1966 F-100 & Larger F-Series Trucks 3 09-09-2016 11:34 AM
Help with vin for a mid 60s f600 chrissmallwood 1967 - 1972 F-100 & Larger F-Series Trucks 7 02-18-2016 02:11 AM
1965 N600 Vin decode stillwater ford Large Truck 1 07-24-2015 05:01 PM
Help with VIN Plate jjreagan 1961 - 1966 F-100 & Larger F-Series Trucks 13 08-26-2013 01:55 PM
Tags
1965, 240, 65, ci, decode, decoder, f100, ford, good, motor, mph, radio, restore, truck, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
