pulling steering wheel - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-29-2009, 09:16 PM
powder runner powder runner is offline
powder runner is starting off with a positive reputation.
I know this sounds like a easy question and I thought it would be a easy job. I hope someone else has come across this. I have a 97 F250 (bronco body style) 7.3L w/out air bags, and I'm trying to pull my steering wheel. So my problem is that the steering wheel does not have the typical holes to thread my puller in like all the others. Is there a special tool out there? Ive already tried to pull really had, and no such luck. Should i just drill and tap some threads into the wheel? Thanks for your help
Old 11-29-2009, 09:43 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
There are no holes at all?
Could you please get us a picture of it?
because its pressed on, you simply wont be able to pull it off unfortunately.
Sometimes, very rarely, you can use your legs to pull it off, but I dont' suggest trying this.
If you drill though to far, you could damage the ring behind the wheel.
However, a 97 bronco should have an air bag, are you sure its the original wheel?
Oh. I read it like you have a bronco. my bad.
Midnight Mods: Steering Wheel Swap/Mod
Look at the picture from my 94 in the article from my web site and see if your wheel is like that.
Old 11-29-2009, 09:52 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
I had the same issue. I got a small two arm puller. Reversed the arms so it grabbed on the inside of the wheel above and below the steering shaft. It's a little tricky but works fine.
And welcome to the forum!
Old 11-29-2009, 09:57 PM
Talyn's Avatar
Weird, they changed the column in 97 then?
Old 11-30-2009, 08:06 AM
tbone heller's Avatar
tbone heller tbone heller is offline
tbone heller is starting off with a positive reputation.
Start the nut back on the steering shaft. place your knees at the 5 & 7 o'clock position. Place left hand at 12 o'clock position. While exerting an upward force at these three points of the steering wheel, hit the end of the steering shaft with a blunt air chisel. The wheel will come right off.
Old 11-30-2009, 05:04 PM
Ill have to give the leg press a try this weekend and if that doesn't work ill go with the two jaw puller , unfortunately the truck is at my moms place so it will take me a a few days before i can let you know how it turns out. Thanks for your advice. I know its crazy that it doesn't have any holes. I'll also take a picture so you guys know im not full of it.
Old 11-30-2009, 05:08 PM
Yes its looks the same as your wheel in the picture Talyn
Old 11-30-2009, 05:24 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
All you really need to do , is loosen the nut 3/4 of the way off, grab the wheel at 9 & 3 . rock it from side to side while pulling (real hard). The nut being on it will keep you from flying through the back window (or hitting yourself in the face ) ...
Old 11-30-2009, 05:33 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
Quote:
You speak from experience Rick? I know I've sure never pulled that little stunt before...
Old 11-30-2009, 05:46 PM
This approach works also, but I have destroyed a few sets of upper steering column bearings & a few clocksprings with this technique.
Old 11-30-2009, 07:27 PM
Yes , I did hit myself in the nose once ....
Never destroyed anything though,(30 + years ), the columns aren't made out of marshmallows...Just wiggle it ....
tbone heller , ,,,,,,,A few ?..................
Old 11-30-2009, 07:29 PM
Doh, double post ....
Old 12-01-2009, 08:43 PM
Yes. In 27 years as a Ford service tech., I have destroyed, worked on, & fixed lots of stuff.
Old 12-23-2009, 05:29 PM
Success
So I finally got the wheel off the other day... I ended up taking off the big center bolt then putting my hands at 3 and 9 o'clock and wobbling back and forth, then switching to 12 and 6 and trying there and the wheel popped off. Thanks for all your help and suggestions
Old 12-23-2009, 06:11 PM
RRranch RRranch is offline
RRranch is gaining momentum as a positive member of FTE.RRranch is gaining momentum as a positive member of FTE.
What did you take the wheel off for. Just curious. I hope it wasn't because some lazy alignment tech said that's how you straighten the steering wheel after he set the toe on it.
94-97 Ford F350 Squeaking Steering Wheel Fix glovemeister 1994.5 - 1997 7.3L Power Stroke Diesel 7 09-18-2014 01:59 AM
Steering Damper? dotcentral 1967 - 1972 F-100 & Larger F-Series Trucks 11 07-07-2014 11:29 AM
Doing things the hard way.....Steering Wheel Removal KJNDIVER 1999 - 2003 7.3L Power Stroke Diesel 16 06-29-2014 07:21 PM
Steering wheel puller creedua 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 06-11-2014 02:01 PM
Power Steering jerks to left or right ch435 Brakes, Steering, Suspension, Tires, & Wheels 4 06-11-2011 06:32 PM
Tags
150, 1999, 2002, 97, f250, f350, ford, pull, pulling, special, stearing, steering, tool, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
