4x4 shift linkage question - Ford Truck Enthusiasts Forums
Old 11-29-2009, 02:33 PM
AZGUY AZGUY is offline
AZGUY is starting off with a positive reputation.
Can someone post pictures of how the linkage from the shifter to the transfer case goes together? I can't seem to find any and my linkage was taken apart before I got the truck and I am not sure the guy gave me all the parts and getting under the truck to switch sucks.
Old 11-29-2009, 07:31 PM
olfordsnstone's Avatar
olfordsnstone olfordsnstone is online now
olfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to behold
I would but I am not at home. I am at work for the next couple of days. If nobody posts up when I get home I will try to remember to send you some pics. That is if you have a pre-77 F250 4x4. You need to post exactly which truck you have. What truck do you have? What year? F250 or F150?
Old 11-29-2009, 07:53 PM
Thanks. Thats a good point. I have a 75 F250 4x4
Old 11-29-2009, 11:25 PM
bmarkline's Avatar
bmarkline bmarkline is offline
bmarkline is starting off with a positive reputation.
Is it a divorced transfer case?
Old 11-30-2009, 12:06 AM
Bgasrickshaw Bgasrickshaw is offline
Bgasrickshaw is starting off with a positive reputation.
Did they have NP203s in '75? If so, the linkage is different from the NP205.
Old 11-30-2009, 12:07 AM
Fordworth's Avatar
Fordworth Fordworth is online now
Fordworth is starting off with a positive reputation.
Quote:
I'm guessing it is divorced but what model is it? NP203s have two rods and therefore two levers that come off the bottom of the shifter while NP205s only have one. Which end do you need to see the shifter on the tail of the trans or the hookup at the T-case?
Old 11-30-2009, 08:05 AM
I only recieved one rod with the truck. It is a divorced transfer case. I will try and take some pictures of my undercarriage today so everyone can see wat I have. I kind of need to see both ends just to make sure I do everything right and hook up both ends of the connecting rod correctly.
Old 11-30-2009, 12:12 PM
OpieCunningham OpieCunningham is offline
OpieCunningham is starting off with a positive reputation.
Check in this thread - I posted the shop manual shifter linkage diagrams for the '77 250, divorced 205.
http://www.ford-trucks.com/forums/88...vagueness.html
Old 01-20-2010, 02:18 PM
That shop manual helps alot but for some reason the place where it should bolt in on my transmission seems to be plugged for some reason. I tried to clean it out thinking it might be just dirt but it is steel. Did the previous owner switch out the transmission with one not from a 4 wheel drive or something? I am kind of at a loss here and would really like to get my 4 wheel drive working without having to crawl under the truck. any help is appreciated.
Old 01-20-2010, 08:54 PM
Is it possible you just have a broken off bolt in there?
Old 01-20-2010, 09:59 PM
I suppose it is possible but it doesnt look like a broken bolt. It is pretty smooth, it almost looks like there is some kind of indented cap on there or something but nothing will come out.
Old 01-20-2010, 10:18 PM
NUTTY4X4's Avatar
NUTTY4X4 NUTTY4X4 is offline
NUTTY4X4 is starting off with a positive reputation.
sounds like a broken bolt id just get a twin stick from northwest fab and be able to do front digs imo (that is if you 4x)
4x4 linkage Thedonk 1987 - 1996 F150 & Larger F-Series Trucks 4 12-14-2015 08:05 AM
AT shift linkage pjinflag 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-18-2007 11:28 PM
C6 transmission kick down linkage deisele75 1973 - 1979 F-100 & Larger F-Series Trucks 5 12-24-2006 06:32 PM
1981 clutch linkage ford390gashog 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 04-01-2006 03:40 PM
Sway Bar Linkage... Smitty1019 1997-2006 Expedition & Navigator 10 03-08-2004 08:34 PM
Tags
100, 1997, 2000, 4x4, case, f150, f250, ford, linkage, linkages, shift, shifter, transfer, transmission, truck, x4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
