1966 Brake Upgrade Question
No, unfortunately. Not even a close fit - although close only counts in hand grenades and nukes anyway!
Now the power booster and master cylinder MIGHT work. I know the rear brakes from an '80s Ford 9" can be swapped, if you use '72 axle shafts on the '66.
Check with AutoZone, Advnace or similar to see if the rotors and calipers are the same. If so, that might save some money. The bell crank for the booster might work too, but you will have to trial fit it to see if it can be made to fit. Seems as I recall when I checked this out, that it was a no-go also.
But the spindles, no, will not work.
IIRC the 80-96 booster is direct acting and the 73-79 booster has that funky rocker in it. They won't bolt on, but may be close enough make work. The master cylinders themselves WON'T interchange.
Looks like we''l be looking for the 73-79 parts.
66nut
25
02-19-2021 05:49 PM
66F100Again
03-09-2007 03:36 AM
