Keyless entry code for 2001 Expedition - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 09-01-2002, 02:38 PM
mbunney mbunney is offline
mbunney is starting off with a positive reputation.
I recently purchased a used 2001 Expedition. In order to operate the keypad on the door you need the factory default number. The manual says that the number can be found on the computer. Can someone tell me where to find the computer?
Thanks
mbunney
Old 09-01-2002, 09:47 PM
TLindquist's Avatar
TLindquist TLindquist is offline
TLindquist is starting off with a positive reputation.
I just bought a 2000 EB 4x4. I read the same thing, don't bother, take the EX to the dealer and they will use the VIN to get the default code or they will "hook up" a computer scanner and scan for the code. Once you have the default code WRITE IT DOWN ON THE SAME PAGE FOR THE INSTRUCTIONS ON HOW TO CREATE A CUSTOM CODE. This way you'll always know where to look.
Old 09-02-2002, 09:48 AM
Acamar Acamar is offline
Acamar is starting off with a positive reputation.
[updated:LAST EDITED ON 02-Sep-02 AT 09:49 AM (EST)]They will also charge you an arm and a leg, too!
I have a '99, so the instructions might be different. Crawl into the wheel well of the driver's side, and look up into the dash, toward the outside of the truck. You will see a black box, with a white label, with a bunch of numbers and sometimes "bar codes" on it. The big five digit number is your master number.
Old 09-02-2002, 02:01 PM
Acamar,
Thanks, I found the code over the brake pedal on a black box. I really appreciate your help.
Thnaks again.
Old 09-04-2002, 07:53 AM
No problem! This board saved me hundreds of dollars with their tips, so I'm returning the favor!
Old 09-04-2002, 06:03 PM
98BIGBODY 98BIGBODY is offline
98BIGBODY is starting off with a positive reputation.
Old 02-18-2007, 10:15 PM
quint32 quint32 is offline
quint32 is starting off with a positive reputation.
Thanks for the help!!
I just got a 2001 Expedition EB and it was right where you said it was. It was on a white box right above the steering stem. This might help with some confusion because in mine there was a black box a little lower with a 5-digit code and a white box deeper also with a 5-digit code. A little trial and error and it worked.
Junkyard parts richsoucie Expedition & Navigator 4 04-06-2015 04:51 PM
Taillights richsoucie Excursion - King of SUVs 8 03-25-2015 09:57 AM
01 Expedition 4.6 Resetting Service Engine Light 01FordExpedition Expedition & Navigator 5 12-01-2004 02:00 PM
How do I replace bulb in 2001 Expidition signal mirror. tactsarge Electrical Systems/Wiring 1 05-15-2004 09:38 PM
performance chip 2001 expedition kjn Expedition & Navigator 2 07-25-2001 11:50 PM
Tags
2001, change, code, codes, default, door, entry, expedition, factory, find, ford, keyless, keypad, location, personal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
