MIXING GEAR RATIOS IN 4X4 TRUCKS? - Ford Truck Enthusiasts Forums
Old 11-29-2009, 01:39 AM
greatdays2gether greatdays2gether is offline
greatdays2gether is starting off with a positive reputation.
iI HAVE AN 97 F150 4X4 3.55 GEARS IN THE REAR DOES IT MATTER IF I CHANGE THE GEAR RATIO IN THE REAR TO A 4.10 4.11 WILL IT AFFECT THE FOUR WHEEL DRIVE?
Old 11-29-2009, 02:08 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
Yes, your gears have to be the same ratio in the rear as in the front. Otherwise the drivtrain will bind severly and deffinatly break something
Old 11-29-2009, 06:02 AM
jplinville's Avatar
jplinville jplinville is offline
jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.
Quote:
Exactly...Both axles must be of the same gear ratio, just like all 4 tires must be the same diameter. Binding and breaking of gears will result...
Old 11-29-2009, 08:05 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Well not exact. Your truck has 3:55 in the rear and 3:54 in the front. \If you went to 4:10 in the rear you would need 4:09 in the front. The fronts for what ever reason are geared lower, i think to pull better
Old 11-29-2009, 08:49 AM
msgtord's Avatar
msgtord msgtord is offline
msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.
I have seen vehicles with lower gears in the rear for bigger paddle tires running at the dunes. Stock gearing up front, depending on front tire size of course.
Old 11-29-2009, 02:49 PM
c_rossman c_rossman is offline
c_rossman is starting off with a positive reputation.
I my wood hauler I have 3.73s in the rear and 3.55 up front. On gravel its fine. Gets me thru the mudholes just fine. just make sure I pull it out of 4x4 before I hit the highway
Old 11-30-2009, 12:21 AM
1994 F250: 351, C6 1994 F250: 351, C6 is offline
1994 F250: 351, C6 is gaining momentum as a positive member of FTE.
Quote:
Only a matter of time before something breaks there.
Old 11-30-2009, 02:56 AM
Prozon's Avatar
Prozon Prozon is offline
Prozon has a good reputation on FTE.Prozon has a good reputation on FTE.
If you're running the same size tires front and rear you should have the same ratio in the front and rear axles.
I can see it working with a different ratio if you ran larger tires on the rear. (Such as the paddle tires mentioned.)
Changing Gear Ratios Daleksandrovich 1987 - 1996 F150 & Larger F-Series Trucks 7 03-22-2014 10:37 AM
gear ratio for 89 f150 bgrabau 1987 - 1996 F150 & Larger F-Series Trucks 1 06-15-2013 12:40 PM
VIN # clue to rear end gear ratio? billnuke1 1999 to 2016 Super Duty 10 12-02-2008 06:27 PM
Gear Ratio Featherman 1973 - 1979 F-100 & Larger F-Series Trucks 22 05-02-2007 08:44 AM
Gear Ratio's on Stock 1999 Superduty V10 4 x4 Ford X Four Modular V10 (6.8l) 1 03-07-2003 08:33 PM
Tags
1983, 1987, 1992, 250, 4x4, changing, f150, ford, gear, gearing, mixed, ratio, ratios, running, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
