Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 11-28-2009, 12:28 PM
cleatus12r's Avatar
cleatus12r cleatus12r is offline
Garage is empty, add now
cleatus12r is a splendid one to beholdcleatus12r is a splendid one to beholdcleatus12r is a splendid one to beholdcleatus12r is a splendid one to beholdcleatus12r is a splendid one to beholdcleatus12r is a splendid one to beholdcleatus12r is a splendid one to behold
Oil Cooler How To...since it's that time of year.
I posted this over at the Nation as well. If anyone is looking to tackle this......
I've been doing quite a few oil cooler reseals lately due to the cold weather and decided since I've ran across a few threads on them, I decided to do a write up on how to. I did this one this morning in about 45 minutes. E99 F-450 2wd.
First, drain the coolant from the driver's side of the block by removing the block heater element.
Here's the removed oil cooler all covered with nasty, baked-on grease.
3 bolts above the oil filter and 2 bolts into the front cover.
Next, I use a rubber dead blow mallet to remove the end caps. They usually fall right off since the seals are hard and brittle.
Here is the oil cooler after cleaning. I usually don't try to clean out the core passages since the oil side is full of fins that can collect dirt and grease....then end up in the engine lubrication system. Just clean the exterior of the core to reduce the chance of damage. The center of the core contains the coolant passages.
I use trans-gel or vasoline to lubricate the o-rings for reassembly. Here is some white grease to show in detail where I lubricate. Don't forget to lubricate the inner chamfer for the coolant o-ring.
Here is how I press the end caps back on the core. The core will eventually slide into the end caps. No laughing at my bald spot or gray hairs.
Also note the locating tab on the rear end cap.
Good luck with the installation of your completed oil cooler reseal. Don't forget to remove the old gaskets and clean the block mating surfaces before torquing the attachment bolts to 18 ft.lbs.
__________________
You don't have to like me. You don't have to like what I have to say. I won't comment on subjects that I don't know anything about but I will set the record straight concerning the things I do.
  #2 (permalink)
Old 11-28-2009, 12:37 PM
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
That's a great write up! I will certainly remember this if/when the time comes!
__________________
97 F-Super Duty, PSD, Auto, Swamps Tunes, 348,000 miles, weighs 13,500lbs
02 F-250, 4X4, PSD, CC, Auto, Swamps Tunes, 115,000 miles
Kentucky Chapter Member
  #3 (permalink)
Old 11-28-2009, 12:51 PM
ernesteugene's Avatar
ernesteugene ernesteugene is offline
ernesteugene has a good reputation on FTE.ernesteugene has a good reputation on FTE.ernesteugene has a good reputation on FTE.
Yuck... those pictures definitely give me "pause for concern" because my "oil cooler" is inside my engine and leaking oil coolers are a known issue for my C7!
__________________
2005 Freightliner ext cab M2 Mountain Master RV Puller, CAT C7 300 HP, 6 speed Allison TRV3000, air locker 4.33 diff, Michelin 255/80R22.5 LRG tires, pulling a 2008 40' triple axle HitchHiker.
  #4 (permalink)
Old 11-28-2009, 01:00 PM
pjwoolw's Avatar
pjwoolw pjwoolw is online now
Throwing darts!
1997 Ford F-250
pjwoolw has a very good reputation on FTE.pjwoolw has a very good reputation on FTE.pjwoolw has a very good reputation on FTE.pjwoolw has a very good reputation on FTE.
Nice write up Cody!
__________________
Pete in San Ramon
2005 F250 6.0 Lariat 4x4 CC Short bed (stock)
1997 F250 7.3 XLT 4X4 Reg. cab (stock)
  #5 (permalink)
Old 11-28-2009, 08:33 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Great write up as always Cody. Now for a question, what does the cold weather have to do with the failure? O-rings shrinking or becoming brittle in the cold?
With the breeze it was a chilly 72 here today, so my definition of cold weather is probably different than yours.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 400,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #6 (permalink)
Old 11-28-2009, 08:44 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is offline
PREMIUM SPONSOR
Riffraff Performance has much to be proud ofRiffraff Performance has much to be proud ofRiffraff Performance has much to be proud ofRiffraff Performance has much to be proud ofRiffraff Performance has much to be proud ofRiffraff Performance has much to be proud ofRiffraff Performance has much to be proud ofRiffraff Performance has much to be proud ofRiffraff Performance has much to be proud ofRiffraff Performance has much to be proud of
/pages/Riffraff-Diesel/103160771064
Brrrrr, Chris Have you broke out the winter jacket yet?
Great write up and awesome pics to the OP.
  #7 (permalink)
Old 11-28-2009, 08:55 PM
Did you have to scrape the frost off the windshield or do you park your truck inside? Time to put the snow plows on and get ready!
__________________
  #8 (permalink)
Old 11-28-2009, 09:20 PM
99hunter 99hunter is offline
99hunter is starting off with a positive reputation.
Great thread, but i have to laugh about you shert.
__________________
Brandon
Late 99 with cold air intake, 4" exhaust, And south bend con OFE clutch with casserly stage 2's
  #9 (permalink)
Old 11-28-2009, 09:31 PM
F350-6's Avatar
Quote:
No, but I've been carrying around the medium coat in the back seat for a couple of weeks. It's cold in the morning.
Quote:
The only plows I've been around are the kind you put in dirt. Even the big cities down here don't own a snow plow.
Quote:
No need to laugh. That's what Cody does for a living.
__________________
Chris
  #10 (permalink)
Old 11-28-2009, 09:40 PM
I'm sorry I was not trying to be mean, I just found it funny with out any harm to any one person or brand. But in all honesty his thread with pictures and comentary Is very good!
__________________
Brandon
  #11 (permalink)
Old 11-28-2009, 09:51 PM
F350-6's Avatar
It's OK. You're allowed to poke fun at him, just no need to laugh. He gets his paycheck one way, but his interests are in the 7.3, right Cody?
__________________
Chris
  #12 (permalink)
Old 11-28-2009, 10:06 PM
It's all good. And all apreciated!
__________________
Brandon
  #13 (permalink)
Old 11-30-2009, 03:20 PM
strokersace's Avatar
strokersace strokersace is offline
strokersace has a very good reputation on FTE.strokersace has a very good reputation on FTE.strokersace has a very good reputation on FTE.
Thanks for this Cody. I'll be doing this to one, possibly 2 psd's in the very near future.
Reps sent.
__________________
Ryan
97 F350 CC Dually psd auto; 38 gal rear tank, Electric fuel, AirDog, Hypermax I/C & Stage 2's, BTS HPOP, SD van turbo, Hydroboost, ARP's, 910's, SB pushrods, Swamps IDM, Tymar, Sound deadening on both sides of firewall, 6.0 trans cooler, SD tranny lines, SD engine compartment conversion, Gauges, HID's, other pretty stuff, ALOT of custom stuff - need BTS trans & bigger turbo
  #14 (permalink)
Old 11-30-2009, 04:27 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
I have been wondering that for a while now.A friends truck will leak at the oil cooler in the winter months here if he don't plug in the heater for a while before he starts it.
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install, DooDad???=(dfuser ram air)
'98 Grand Cherokee, '86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #15 (permalink)
Old 11-30-2009, 05:31 PM
cleatus12r's Avatar
I would have to say it is a combination of the cold and the o-rings becoming brittle......only because the o-rings usually come off in two pieces (and if they didn't break coming off, they never would since they are hard as a rock).
Not too many oil cooler seals get done around here until it gets cold.
We have been living in the 40's for highs lately but the mornings are in the single digits. This weekend is supposed to be around 0 for lows.
__________________
Tags
1999, 69, 73, cooler, diesel, f250, kit, oil, oring, picture, powerstroke, removal, removing, replacement, ring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
