check out the pics in my profille and you can see what a leveling kit looks like on your body style truck. mine has 31's on it. as far as leveling it out you can either replace the whole spring, or put in a spring spacer. the whole idea of a spacer made me a little uneasy so i just replaced the spring. cost wise the spacers, and the springs are just about the same. yes, you will need to replace your shocks as well. i bought all of my stuff from roughcountry.com. i replaced all six shocks and the springs. install time of it prolly only took about and hour and a half. nothin too complicated there. one thing also is that lifting it will throw your truck out of camber so you will need to get new camber bushings. installing them is a major PITA. if you dont wana mess with it any decent alignment shop can swap em out for you. so basically what i would reccomend is : springs, shocks, camber bushing, alignment. all in all, it ended up costing me about $300 in parts, and then about 450 for new 31's and i couldnt be happier.
__________________
FORD......Found Off Road Diggin......
Quote:
Originally Posted by 6CylBill
The only way this Bronco could get any better is if Jessica Alba and Lindsey Lohan made love and waxed this Bronco with their combined love juices.
1995 F150 Flareside w/ six cylinders of fury, 4x4 and leveled out with BFG 31's
