Oil Change Bucket - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Oil Change Bucket
Old 11-27-2009, 08:53 PM
richartdana44 richartdana44 is offline
richartdana44 is starting off with a positive reputation.
Oil Change Bucket
What is everyone using to drain their oil into? I have a 01 F250 with the 7.3 auto. But it is a 2 WD so it sits lower to the ground. A regular 5 gallon plastic bucket will not fit under the oil pan. Trying to switch containers during the draining process makes a huge mess. Is there a special low sided container made that can hold up to 15 quarts of oil?
Old 11-27-2009, 08:55 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Yup! Cut 4-6" of the top of a 5 gallon bucket. Wala. You have a 4 gallon bucket
Old 11-27-2009, 08:57 PM
superdutyduck's Avatar
superdutyduck superdutyduck is offline
superdutyduck is starting off with a positive reputation.
get a plastic tote with a lid! that way you can store the oil in a rack system or put it in the back of the truck and take it to the recycler!
Old 11-27-2009, 08:58 PM
or make an attachment for the shopvac and suck the oil out and then you know the rest!
Old 11-27-2009, 09:10 PM
Thanks for the ideas, but was hoping someone had manufactured a regular oil drain pan just in a larger size. I tried the cutting of an existing bucket but without the top ring in became pretty unstable. Sliding it out from under the truck was not pretty.
Old 11-27-2009, 09:12 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
Cat litter bucket
Old 11-27-2009, 10:46 PM
conger's Avatar
conger conger is offline
conger is gaining momentum as a positive member of FTE.conger is gaining momentum as a positive member of FTE.
How about not using a drain bucket at all. Have you heard of a Fomoto drain valve? I use one on my 6.0, but they also make them for the 7.3.
I drain my oil directly into my old waste oil and washer jugs. I just plug a short piece of hose on the drain spout of the Fomoto valve and fill one jug at a time, opening and closing the valve as needed. Absolutely no mess at all.
Old 11-27-2009, 10:49 PM
do they make them for the 6.8?
Old 11-27-2009, 10:56 PM
conger's Avatar
Quote:
I don't know. I've never seen them advertised for gas engines. But I'd check to see if the drain plug for the 6.0 and the 6.8 are the same size. The Fomoto valve just replaces the drain plug on the oil pan. Now that I've done oil changes this way, I wouldn't go back to a plug. It was the first mod I did to this truck. A lot of bang for 30 bucks.
Old 11-27-2009, 10:58 PM
just seems like it would be cleaner also! do they have a website?
Old 11-27-2009, 11:01 PM
i googled it and they do have a website: FUMOTO ENGINEERING. and here is the list for their ford parts. (copied and pasted)
Ford All 4 cylinder engines (except '96 & on 2.3L, '98 & on 2.5L, '97 & on Escort & Focus engines) F-106
'00 & on Focus 2.0L DOHC engine. 2.3L('04 & on), 2.5L('04 & on) 5.0L('91 & on), 5.8L('93 & on), 7.5L(460 - July '85 & on), V-10(6.8L) engines. F-106
00 - on Focus 2.0L SOHC engine, '97 - on Escort 2.0L. 2.3L('96-'03), '95 & on 2.5L(V6), '97 & on 4.2L engines F-107
2.8L, 2.9L, 3.0L(except 24V), 3.2L, 3.4L, 3.9L, 4.0L, 4.6L, 5.4L, & 6.8L(V-10) engines F-106
94 3.8L(Mustang requires adapter ADP-106) F-106
7.3L ('95 & on). 6.0L diesel('03 & on) & 6.4L('08 & on) Powerstroke diesel engines. F-111
95 - on 3.8L engine (requires adapter ADP-107) V6 2.5L('96 & on), 4.2L('96 & on), 3.0L(24V) F-107
All other engines F-101
Old 11-28-2009, 12:23 AM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
I just use one of these.
Old 11-28-2009, 12:46 AM
thedaddycat thedaddycat is offline
thedaddycat is gaining momentum as a positive member of FTE.
I bought one kind of like Redford showed, but it has an open top. It's yellow and it's really big, 20+ quart I think. I can drain the oil from my truck no problem and have room to spare. I think I got it at Wall-to-Wall Mart.....
Old 11-28-2009, 08:47 AM
Quote:
Thats what i use. and i have never had an issue w all the oil not fitting. And when the filter drops out of your hands , you dont get a bath in waste oil
Old 11-28-2009, 10:58 AM
Quote:
That's not an issue with a 6.0........ lol
With the setup I have, having room for all the oil is though. It took 17 quarts to fill it up when I installed the extra systems.
http://www.ford-trucks.com/forums/77...installed.html
Draining FE Engine Oil --- NEATLY flowney 1973 - 1979 F-100 & Larger F-Series Trucks 11 06-07-2016 12:50 PM
Drained LPFP, now what--dump on neighbor's flowers? Icthus in AK 6.7L Power Stroke Diesel 15 10-10-2014 03:35 PM
DFCM won't stop draining elee3 6.7L Power Stroke Diesel 17 03-24-2014 08:58 AM
VW Passat oil cooler fail - need advice. Kwikkordead General Automotive Discussion 9 01-01-2011 10:45 AM
Oil Drain Valves? PW01 Oil & Lubrication 8 01-12-2006 12:19 PM
Tags
20, 96, bucket, buckets, capacity, change, drain, f111, f150, f350, fumoto, lightning, oil, plastic, truck, valve, waste
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
