You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
What are you guys working on in the garage this winter?...................We are building a new 2.3 Ford 4 for my buddy's 83 Ranger 4x4................Lots of nice aftermarket parts for it, a lot more than were avail. for my 2.8 v6. Since its not a daily driver, we have time to do it right!...............What kind of "garage money holes" are you guys working on?
__________________
93 F-250HD SC 460 E4OD
96 Explorer Limited 4.0 V-6 OHV
93 Ranger Splash 2.3 5spd only 51,000 miles!
84 Ranger 4x4 2.8 V-6 5spd......450,000 miles, now on a brand new 2.8
Dave
Oregon Assistant Chapter leader: To join the Oregon Chapter, click HERE
I have two projects to do this winter. The first is to bring in my 73 HiBoy chassis and remove 16" from the middle of the frame, weld it back together and install my 53 FORD panel onto the shortened frame. Then I have to paint the top of the hull on my 16' Sidewinder ski boat with the new red metal flake, and install the new 200hp in-line 6 into it. I'd like to have both ready for a GTG on the Columbia River this summer.........
Bikini's and water skiing, is there anything better!
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
I'm working on the rubber around the windows of my 66. The antirattle kits are a real pain.
__________________
Allen D
1966 F-100 4x4 with 390 GT engine
1990 Areostar 2wd XLT ext
1980 Bronco with 460
1976 F250 4X4 Custom with 429
Oregon Chapter Member: To join the Oregon Chapter, click HERE
well im going to start restoring my 71 f-100 and to start it off i just put a HOLLEY 650 Double Pumper on it
and starting the sas in my B2 to a 9in rear and 44 front
__________________
Iron sharpens iron; so a man sharpens the countenance of his friend. Proverbs 27:17
1988 Bronco II 4x4 chopped top & soft top 4in lift
1971 f100 4x4 390 4speed solid truck RESTO project
My B2 project fell thru when my wife took ill, I just wish I could find a decent 84-88 B2 to restore with no major mods and drive................My 15 yr old Daughter is taking over my 84 Ranger 4X4 V6 a little bit at a time.........She hates cars, and only wants a 4x4 truck.
__________________
Dave
I wish I had some place to work on my wood drift boat. (no garage or shop)
__________________
Chris 1989 F-250 Super Cab 4x4 5.8L 5 speed now calling Frankenstein
"There are only two ways to live your life.
One is as though nothing is a miracle.
The other is as if everything is. "
~ Albert Einstein~
getting my tail wooped by my winter project my headers will not seat up on the passenger bank of the motor
You may have to pull the bolt holes a little with a die grinder, works wonders.
__________________
Dave
Air powered straight grinder with a carbide burr tip, does about 22,000rpms. Will elongate any bolt hole to make up for error in bolt pattern.
__________________
Dave
Are you building one or restoring one?..........1 guy I knew just rented a big storage unit over the winter to work on his boat and truck. It had power and he brought in lights, worked very well.
__________________
Dave
got the tail pipes done and sealed up now just have to get the passenger side header to seat up they just won't seal up not sure if there may be something wrong with the header surfaces to the head will probably take it back apart and look at the gaskets that i just put in and look at the problem hope nothing that i can't handle
__________________ Allen D. Jr
1966 Custom cab truck
1967 Fairlane Ranchero
