Bear claw latches / original door handles ?
I like safety and reliability over originality any day. If I were to use bear claw latches on my 51 f-1 , will I be able to use the original interior and exterior door handles ? If so what do I need to do to make them work? I thought I saw this on F T E , but was unable to find it with the search. I don't want to rebuild the old ones . Since I have five of them I plan to put them on ebay and go with new.
You will need to fab up some connections from the handles to the latch. You can use 1/8' rod from the hardware store or some small cable. Check with Rocky Hinge Co. He may have some items already fabbed for this. Another possibililty is the Altman latch. Do a google on it or a search here on FTE.
It's a fairly simple fab job, but does take some a little thinking and planning. A small tab to fit on the square shaft with a rod connection to the latch will work well, similar to what you'd find on a door lock, if you're familiar with that. Making the inside work too, you need to engineer a bypass system between the two rods, at the latch, so you're not pulling against one while using the other.
I've personally never been very keen on bear claw latches. They seem to have a "hair trigger" in that it doesn't take much to open them, they don't have a two-stage latch system like OEM uses, and they have no provision to lock the door. My 2c.
Years ago, when I was working in a custom shop, a customer brought in a set of bear claw latches, and wanted us to install them. One of the other guys picked it up, looked at it a bit, latched it, then smacked it in the palm of his hand and it popped open. He started playing with it like a toy, latch, smack-unlatch...latch, smack-unlatch...latch, smack-unlatch...you get the picture. It's been several years now since I've messed with them, so hopefully they're better now, but I wouldn't count on it.
I watched that Atlman video, it didn't show me what I was wanting to know. The bear claw latches I'm referring to are shown in the link below. They are the highly popular parts sold by many street rod parts places, and other stores, I'm sure, also. I have no idea if these are the same parts in the kit shown in the video. They never showed the parts they used in their conversion, and I was looking, too, because I wanted more info on their product. I fear people may be using the "bear claw" name generically. I am trying to be fair to everyone, while sharing my personal experience.
Bear Claw Door Latches - Juliano's Hot Rod Parts & Interior Products
Oh, and the rope trick would be a good idea, and I couldn't blame your wife for her unhappiness. :-)
I looked at your latch install, looks real good. Do the latches have a secondary catch to keep the door from flying open or are they fully open as soon as you touch the switch? Were there any problems wayne discribes in post #9 , when they would open so easy?
i`ve installed a set moons ago and they were a 2 stage looks like the oem`s, just installed one for my side opening tailgate and it was definately a 2 stage, never unlatched when i was playing with it? is there a possibility of different manufacturers of these latches, different tolerances?
