2008 ford edge trans problems - Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
Old 11-26-2009, 10:47 AM
02sd 02sd is offline
02sd is starting off with a positive reputation.
when the truck warms up and sitting at a light, When the light goes green and you try to give the edge some gas it slams into a gear, feeling like we have just been rear-ended! making some odd noise also
The ford trans tech said if there is no light/codes there is no problem
But obviously there is a problem
and Ideas what it is?
Old 11-26-2009, 01:19 PM
I just took it for another ride, up a hill and stoped it feels like its maybe in reverse and fwd. as it will not roll back or go forward until you rev the engine to about 2000 rpm and it gives a hard bang and goes into your fwd gear again.
A quick stop does not do this it will act normal.
Old 11-27-2009, 07:11 AM
tiny1's Avatar
tiny1 tiny1 is offline
NY CHAPTER LDR
tiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputation
Just a curiosity question.... how is the transmission fluid level ???
The reason I am asking is that after I had the tranny serviced in my truck it would "slam" into gear like you mention becasue the fluid level was down. The tech forgot to recheck it after it ran.
Old 11-27-2009, 08:41 AM
Fluid is fine, checked it a million times as its such a POS dipstick, it seems to have the same symptoms as the TSB #0723-2 for the explorer 6 spd where it calls it bump/wall braking , on the explorer it only does it if the fluid is at operating temp, exactly the same way my edge acts up once the trans oil is fully warmed up.
Old 11-27-2009, 08:59 AM
tiny1's Avatar
NY CHAPTER LDR
We have not had any issues with ours but we have 13K miles on it.
Is there another dealership that you could take it to ??
Old 11-27-2009, 01:56 PM
its at a different dealer right now
I should maybe know something monday
thanks,
Old 11-27-2009, 02:36 PM
tiny1's Avatar
NY CHAPTER LDR
Good luck with it and when you find out the issue, please post it up in here for everyone else.
Old 11-30-2009, 11:46 AM
countryboy69's Avatar
countryboy69 countryboy69 is offline
countryboy69 is starting off with a positive reputation.
there is a pcm reprogram for the 6f50 transmission tsb # 08-26-13. very simular to the explorer reprogram
hope this helps
Old 12-05-2009, 06:55 AM
fordmdb's Avatar
fordmdb fordmdb is offline
PREMIUM SPONSOR
fordmdb has a great reputation on FTE.fordmdb has a great reputation on FTE.fordmdb has a great reputation on FTE.fordmdb has a great reputation on FTE.
thanks,
HI 02sd
Any update on this?
__________________
Custom Tuning for F-E-Series Engines 6.8L V10 / 5.4L V8 / 4.6L V8 / 6.2L V8 / 5.0L V8 / 3.7L V6 / 3.5L V6 / 3.5L EB / 2.7L EBand more!
SCT Custom Tuning Dealer
www.5startuning.com email me here:sales@5startuning.com 843-536-1244
https://www.facebook.com/pages/5-Sta...92086367552400
Old 12-05-2009, 06:59 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Ditto, except ours has 18,000 miles.
Old 12-05-2009, 08:15 AM
well right now the ecu trans controller is ordered at ford
It goes inside the pan covered with oil
I will let you know once this has been installed
the programming did not help
Old 12-24-2009, 11:40 AM
tiny1's Avatar
NY CHAPTER LDR
any update on this ???
Old 12-24-2009, 04:41 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
a Trans control module is probably in order.
Old 12-25-2009, 12:00 AM
I replaced the ecu trans controller and trans is working properly.
Old 12-25-2009, 05:41 AM
senix's Avatar
exactly what I thought. More often than not the trans now is controlled by a computer that talks the eng computer now.
Transmission Going into "Safe Mode" Joseph D. Kendall 6.0L Power Stroke Diesel 34 01-12-2016 07:54 AM
2005 6.0 edge programmer fried my ficm fordfreak05 6.0L Power Stroke Diesel 10 06-23-2012 12:29 AM
Code p0783 o/d light blinking late 3/4 shift 2002exPSD 1999 to 2016 Super Duty 5 02-16-2012 09:01 PM
Code P0731 and Edge xjcamaro89 2004 - 2008 F150 14 11-20-2009 07:20 PM
Towing of the Ford Edge USMC Ret Crossovers 2 12-03-2008 07:31 PM
Tags
082613, 2008, awd, banging, edge, f150, ford, level, noise, problems, reprogram, sel, taurus, tsb, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
