Oil leak, turbo, EBPV?? - Ford Truck Enthusiasts Forums
Old 11-26-2009, 10:35 AM
jt371's Avatar
jt371 jt371 is offline
jt371 is gaining momentum as a positive member of FTE.
First things first.....HAPPY THANKSGIVING to all!!!!!
The other day I was looking over my truck and noticed that my engine oil level was a little low. Added oil and checked it over and found there was oil leaking down the back of the motor. Looking on the top side noticed a little oil residue coming from the back of the engine valley towards the front. Looking harder noticed that there was oil under the turbo on the EBPV/pedestal. I have had my EBPV stick when its cold evan after I cleaned the EBPV sensor tube last year. This summer was under my truck with it running checking the CCV hose and thought it might have pressure behind it.
So my question is is my EBPV bad? Can it be rebuilt, seal kit? Is it just bad o-rings on the base of the turbo? I have the o-rings for base of the turbo. I just don't want to take it all apart and not have enough parts to fix it.
Thanks in advance.
Old 11-26-2009, 11:59 AM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
Yes, you can rebuild it with all new parts. Here is the kit that has everything you need.
Have a Happy Thanksgiving
Riffraff Diesel: Exhaust Backpressure Valve piston rebuild kit
Old 11-27-2009, 10:02 AM
jt371's Avatar
Thanks Clay.
Do you have the generic o-ring kits from Guzzle as well? I should look at getting one of those as well.
Thanks
Old 11-30-2009, 01:51 PM
aklim's Avatar
aklim aklim is offline
aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.
Here is my personal experience so take it FWIW. We thought the pedestal was leaking so we changed that set of O-rings. Still leaked. Rebuilt the EBPV with the kit. Still leaked. Got a new EBPV. Still leaked. Another one and finally it quit. Why? I suspect because the bore was scored and changing the piston would not help. When they gave a rebuilt one to be installed from the parts dept, they just changed the rubber plunger which did not fix the bore. Talked to another tech who had 3 rebuilt pedestals before they found one that would NOT leak.
Old 11-30-2009, 02:10 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Put in a non-EBPV pedestal and remove the EBPV while you have it off. No more leaks.
Old 11-30-2009, 02:27 PM
jt371's Avatar
OK thanks for the info.
I would just remove it but like the idea of it warming the engine faster in the colder months.
Old 11-30-2009, 02:41 PM
aklim's Avatar
I don't feel I have lost much in the cold months after I removed the EBPV and changed to the van turbo.
Old 11-30-2009, 03:13 PM
jt371's Avatar
Like I said, I liked the idea, I know some have done as you have and still operate during the colder months. Also I don't want to spend the cash to swap it out. I hope I can clean up the bore and rebuild it. Someday I'd like to upgrade the turbo but for right now i need to just keep everything going.
ebpv Liquid10Rider 1999 - 2003 7.3L Power Stroke Diesel 7 12-11-2012 04:58 PM
Leak at turbo pedastal - Help guitarpicr 1999 - 2003 7.3L Power Stroke Diesel 14 06-04-2012 09:31 AM
Turbo Pedestal Oil Leak Question disneyd 1999 - 2003 7.3L Power Stroke Diesel 1 04-14-2011 11:50 AM
Fixed the Gusher????? empireweld 1999 - 2003 7.3L Power Stroke Diesel 12 02-13-2010 05:10 PM
oil leak unluckylow 1999 - 2003 7.3L Power Stroke Diesel 16 10-22-2005 10:15 PM
Tags
1999, 250, 73, 99, cold, diesel, ebpv, f250, ford, leak, leaking, oil, powerstroke, side, top, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
