cruise control and od question
I added it to my XL truck a few months ago.
Dealers no longer make the conversion kit.
The only thing you need is a steering wheel and clockspring, and the rest is already there.
I ended up buying a new steering column that included the wheel and airbag and everything. It was 175 bucks at a truck salvage yard. It also was a tilt column, which I did not have, so it was WELL worth it.
The only other thing you need to do is figure out what you want to do about the sensor that is supposed to be on the master cylinder, as there is no way to put it on the master cylinders for non-cruise trucks.
The kit from ford came with a switch and wiring to hook it up inside the cabin on the brake pedal.
I looked at the wiring and noticed it was redundant to the switch on the brake pedal that controls the brake lights, and it is a normally closed switch, so i just put a jumper across the connector under the hood, and the cruise works perfect.
If you need any help, let me know via PM. I've done all the legwork and it was VERY time consuming. I'd be glad to put all this knowledge to work.
